<A HREF="http://forumz.tomshardware.com//modules.php?name=Forums&file=viewforum&f=7" target="_new">Check out the new Case Mod and PSU section of the THGC</A>
Why did you raise them? Stability problems? You should have been fine at the previous levels.
Go to the memory FAQ which is the first thread in this memory forum. In there you will se something for a SPD tool. It should be able to read the SPD chip on your module and display what the settings are. (CAS Latency being one of them)
