Archived from groups: rec.games.chess.computer (
More info?)
I now get an insufficient memory message when I start up the program!
I am reluctant to re-install it because I mistakenly threw away the jewel
case when I re-organized my software last year. I therefore no longer have
the registration #. It's ironic that I have never copied commercial software
and now I'm stuck. I will have to beg CB for another # as I had to do with
the Chessbase program.
I'll try the update.
Angelo
"muppet0830" <mup@pet.0830> wrote in message news:4315a901_3@x-privat.org...
> You haven't yet said which version of the Chessbase GUI you are using.
> Some earlier versions couldn't handle more than 512 MB RAM, if I recall
> correctly.
> muppet0830
> "Angelo DePalma" <angelodpnospam@nospam.gmail.com> wrote in message
> news
hGdnTuDHc6W0ojeUSdV9g@ptd.net...
>> I can now alternately get the program to load Fritz 5.32 or Shredder as
>> the playing engine, but the program freezes when I try to load one of my
>> other engines as the playing engine. However, I cannot switch the
>> analysis/evaluation engine. It is locked on Fritz 5.32. If I try
>> switching it it either tells me there is not enough memory, or it
>> freezes.
>> Also, when you play a game against the computer why does it ALWAYS prompt
>> for a result? Why can't that prompt be optional? I have no interest
>> whatsoever in recording my games against a 2600+ computer.
>> Is it possible to turn off that feature?
>> news:8fadna1sVLwwiojeUSdV9g@ptd.net...
>>> THanks, I'll look into these possible solutions.
>>> news:43150a04_3@x-privat.org...
>>>> news:UsecnSDZHeu7b47eUSdV9g@ptd.net...
>>>>> I am unable to switch my main engine in Shredder. For some reason
>>>>> Fritz 5.32 is now the default engine. When I go to the engine
>>>>> management tab and switch main engine, it tells me there's not enough
>>>>> memory. I have 2 MB of RAM on my computer.
>>>>> Help?
>>>> Now that we've clarified that you have 2 GB RAM (not 2 MB)...
>>>> Solving such a problem requires a logical stepwise approach where you
>>>> write down a list of possibilities then test them (rule them out) one
>>>> at a time. For someone else to diagnose the cause of your problem
>>>> requires much more info such as details about your op system, software
>>>> and hardware, and the various system and software program settings
>>>> you're using. It's not necessarily easy but sometimes you get lucky.
>>>> Eventually if all of the software and op system possibilities are ruled
>>>> out, then you should begin to suspect a hardware problem. For example
>>>> hard drives go belly up fairly often, in my experience, so you might
>>>> run a diagnostic on yours. But first a few quick simple stupid things
>>>> to do...
>>>> Turn off tablebase access until this problem is solved.
>>>> Can you switch to other engines besides Fritz 5.32? Forget about
>>>> Shredder, for now. Can you switch to any other engine? Or is it
>>>> permanently stuck on Fritz 5.32?
>>>> How much RAM do you have allocated to hash tables? Reduce that to 4 MB
>>>> or some such small number to rule out it as a cause.
>>>> Which Chessbase GUI are you using? The one that came with Shredder 9,
>>>> or a different one? Regardless, at this point, you should probably
>>>> uninstall then reinstall it to rule out a corrupted installation.
>>>> You're probably running Windows XP and may have System Restore actively
>>>> monitoring your computer so you can recover after a crash. That can
>>>> cause problems. The test is to turn off System Restore for awhile and
>>>> see if that makes any difference.
>>>> Virtual memory can be a problem if you're using special settings. If
>>>> you let windows handle it (the default), that shouldn't be the cause.
>>>> There are better settings than the windows defaults but that's
>>>> irrelevant here.
>>>> Nuf for starters...
>>>> muppet0830
