Where are engine-engine games stored?
Last response: in Video Games
Archived from groups: rec.games.chess.computer (More info?)
I'm having fun with my newly-functional Shredder 7 interface.
I'm running a G/3 (minutes) contest between Shredder7 and Fruit, the free
engine. So far after 19 games Fruit is winning, 19-7.
My question is: Are these games stored anywhere? I have not been able to
find them. Some are quite fascinating.
Angelo
Angelo
More about : engine engine games stored
> Angelo
somethinglike:
documents and settings/"username"/documents/Chessbase/compbase/engtourn.cbh
"username" is probably you in your case
HD
> Angelo
somethinglike:
HD
THanks, HD. I'll check it out.
Engine-engine matches are incredibly interesting.
"HD" <hdchess@gmail.com> wrote in message
news:431a0415$0$18639$14726298@news.sunsite.dk...
>> Angelo
> somethinglike:
> documents and
> HD
>> Angelo
> somethinglike:
> documents and
> HD
Thanks, it was right where you said it would be.
By the way, after 121 games at G/3 minutes, the score is Fruit 63 - Shredder
58. At this time control Fruit appears to be as strong as Shredder. Some of
these games are absolutely amazing to watch.
Anyone interested in the game scores, let me know.
Angelo
>> Angelo
> somethinglike:
> documents and
> HD
Angelo
>> Angelo
> somethinglike:
> documents and
> HD
Related ressources
- shredder problem - Forum
- Where is Solitaire score stored ? - Forum
- Where are downloaded maps stored ? - Forum
- Slow UT minimize with Radeon cards, too? - Forum
- OpenGL - Forum
> Angelo
Funny enough, both authors claims that their programs is bad, "or not so
good" at bullet/blitz... Most tests - also against other engines -
hasn't comfirmed that.
And yes, watching engines play, can be very fascinating!
HD
> Angelo
HD
I had the two engines play G/10 minutes + 3 seconds/move overnight, and so
far the result is Fruit 14, Shredder 13. I can't wait to see the slow games.
news:431a8bf3$0$18650$14726298@news.sunsite.dk...
>> Shredder 58. At this time control Fruit appears to be as strong as
>> Shredder. Some of these games are absolutely amazing to watch.
>> Angelo
> good" at bullet/blitz... Most tests - also against other engines - hasn't
> comfirmed that.
> HD
>> Angelo
> comfirmed that.
> HD
On Sun, 4 Sep 2005 11:27:27 -0400, "Angelo DePalma"
<angelodpnospam@nospam.gmail.com> using recycled electrons muttered something
about:
> Angelo
Hi Angelo,
I would be interested in the having the games if you could zip them and mail
them to:
dayffd at earthlink dot net.
>> comfirmed that.
>> HD
The games can be especially interesting if the parameters are changed a bit.
For example, when starting a tournament, instead of leaving the "book" settings
at their default, try this: New Tournament/Invite Engine/ (pick an engine, then
Edit the engine)/Book choice (pick a book, e.g. Fritz 8 book)/Book Options (2nd
button down)/ click on "Normal" - note how the variety of play moves to ~80% -
and then increase (or not) the influence of the learn value slider and the
learning strength all the way to the right. Now, your engines will start playing
things like King's Gambits, Faulkbeer Counter-gambits, Benko/Volga gambits, and
other openings, some mainstream, others not so mainstream.
The variety
increases tremendously.
Also, with some programs, Shredder being one, you can change the values of the
pieces. Try dropping the value of a pawn by one or two, from 100 to 98 or 99.
Then have it prefer open games. Suddenly, Shredder will be much more willing to
sacrifice a pawn to open a position up. This is not to say that Shredder will be
stronger, indeed, it may even weaken it a bit, but the games can become much
more interesting imo, and worth looking at closely if you like attacking games.
You can also add to your opening books via File/Open/Opening books. Open the
book of your choice. Then, under Edit,/Openings book, you can import games,
combine opening books by "Import book",etc. Be careful, though, when importing
games, the amount of space used up becomes enormous. Leave the cut off number of
moves at the default of 20. Increasing this number results in humongous files.
Anyways....
No problem is so formidable that you can't just walk away from it.
about:
> Angelo
Hi Angelo,
them to:
>> comfirmed that.
>> HD
The varietyincreases tremendously.
Anyways....
I'd be happy to send you the games. Do you prefer PGN, ZIP, or CBV?
I'm very interested in implementing some of your ideas. The results would
make an interesting book!
By the way, Fruit won the G/10 match 16-14. So far we have played two G/60 +
3 seconds, and Fruit is ahead 2-0, and has a slight advantage in game 3.
My observations: Fruit tends to use considerably less time than Shredder at
all time controls, especially G/10 and longer. Fruit also appears to be a
deadly endgame player. In one of the G/60s it was down a (doubled) pawn with
rook-file passers on both sides, plus 2 rooks. I was about to adjudicate the
game as a draw but I'm glad I didn't because Fruit won handily. It was quite
a game.
<Chaos@chaos.org> wrote in message
news:38fmh11jsdalo8orrcgqu8529o5h0cdde2@4ax.com...
> something
> about:
>>games.
>> Angelo
> Hi Angelo,
> mail
> them to:
>>> hasn't
>>> comfirmed that.
>>> HD
> bit.
> settings
> then
> (2nd
> ~80% -
> playing
> gambits, and
The variety
> the
> 99.
> willing to
> will be
> much
> games.
> the
> games,
> importing
> number of
> files.
> Anyways....
a game.
> something
> about:
>>games.
>> Angelo
> Hi Angelo,
> them to:
>>> hasn't
>>> comfirmed that.
>>> HD
> bit.
> settings
> then
> (2nd
> ~80% -
> playing
> gambits, and
The variety> increases tremendously.
> the
> 99.
> willing to
> will be
> much
> games.
> the
> games,
> importing
> number of
> files.
> Anyways....
Actually the results of the G/10 + 3 secons was Fruit 18, Shredder 14.
That's a significant difference to me.
> something
> about:
>>games.
>> Angelo
> Hi Angelo,
> mail
> them to:
>>> hasn't
>>> comfirmed that.
>>> HD
> bit.
> settings
> then
> (2nd
> ~80% -
> playing
> gambits, and
The variety
> the
> 99.
> willing to
> will be
> much
> games.
> the
> games,
> importing
> number of
> files.
> Anyways....
> something
> about:
>>games.
>> Angelo
> Hi Angelo,
> them to:
>>> hasn't
>>> comfirmed that.
>>> HD
> bit.
> settings
> then
> (2nd
> ~80% -
> playing
> gambits, and
> the
> 99.
> willing to
> will be
> much
> games.
> the
> games,
> importing
> number of
> files.
> Anyways....
On Sun, 4 Sep 2005 17:44:08 -0400, "Angelo DePalma"
about:
pgn files, zipped would be my preference.
What version of Fruit? Fruit 2.1 is the strongest.
I've already made a couple of books, with some additional material. But yes, a
book with GM analysis would be interesting.
I made a couple of settings for CMX (Chessmaster 10) that I've been testing
against various engines in 10 minute blitz. The results have been good, but so
far against fairly dated engines: Fritz 5.32, Nimzo 7.32, Hiarcs 7.32, Zappa
1.0, and Crafty 18.15. I'm still running tests, but I doubt these settings are
as good as others. These settings make Chessmaster 10 pretty aggressive, but
also it seems to me the engine, with these settings, the play is nearly
indistinguishable from that of a strong human master, playing moves a human
would make rather than a chess engine. Fascinating to watch!
about:
I'm fascinated that you're interested in human-like computer play. I am
also, but not from the point of view of making the program stronger. I would
like to set an engine up so it plays human-like at the 2100-2200 level. I
think it would be a good opponent for me (I'm around 1900).
I'll send you those files as zipped PGN tomorrow or Tuesday. I'd like to
wait for the results of the G/60s.
BTW, as these engines become capable of beating a higher and higher
percentile of GMs, I believe human analysis is becoming irrelevant. There
was a time when a GM or strong IM could poke fun at chess engines. The term
"computer chess" was used in a derogatory manner to describe machines that
apparently did not possess the planning and strategic vision of humans. I
have a position from one of my games, where I beat a much-higher rated
player in a study-like ending. I saw the long series of moves that won the
game by force, but to this day my Shredder cannot.
Still, I would trade any 2600 player's (and probably any 2800 player's)
chess knowledge and strategy -- all the stock "plans" for playing the
canonical positions -- for the sheer calculating power of one of these top
engines. They will beat any Nimzoindian expert (or Kalashnikhov expert, or
Benoni expert, etc.) at their own game time after time. It is becoming
difficult, even silly, to argue with that kind of success.
What do you think?
Angelo
news:c4smh1p9febuc2ln2lmn75eidnugd8cmvs@4ax.com...
> something
> about:
> yes, a
> testing
> but so
> Zappa
> are
> but
> human
What do you think?
Angelo
> something
> about:
> yes, a
> testing
> but so
> Zappa
> are
> but
> human
On Sun, 4 Sep 2005 23:56:43 -0400, "Angelo DePalma"
about:
Actually, it was not until I was watching this engine/settings play that I
became interested in seeing how like a human this one plays. Here are a couple
of games fro one of the matches:
[Site "Riverdale"]
[Date "2005.09.04"]
[Round "2.1"]
[White "CMX Dayffd 1.0"]
[Black "Junior 6.0"]
[Result "1-0"]
[ECO "C48"]
[BlackElo "2451"]
1. e4 e5 2. Nf3 Nf6 3. Nc3 Nc6 4. Bb5 Nd4 5. O-O Nxb5 6. Nxb5 c6 7. Nc3 d6 8.
d4 Qc7 9. Bg5 Be7 10. h3 O-O 11. Qd2 Be6 12. Rad1 Rfd8 13. d5 Bc8 14. Rfe1 h6
15. Bxf6 Bxf6 16. b3 Be7 17. Ne2 Bd7 18. c4 a5 19. Ng3 a4 20. b4 cxd5 21. cxd5
Qb6 22. Nf5 Bxf5 23. exf5 Rdc8 24. Rc1 Qb5 25. a3 Rxc1 26. Rxc1 Bd8?
{Better is 26...Bf6!}
27. Qd1 Bb6 28. f6! g6 29. Nh2 h5 30. Nf1 Bd8 31. Qf3 Rb8 32. Nd2 Bb6 33. Rc4
Bd4 34. Rc7 Bb6 35. Rc2 Ba7 36. Rc3 Re8 37. Rc4 Bd4 38. Qe4 Rd8 39. Rc2 Rf8 40.
Nf3 Bb6 41. Ng5 Qd7 42. Qc4 Ra8 43. Ne4 Rf8 44. Rc1 Ra8 45. b5 Qf5 46. Qe2 Rc8
47. Rxc8+ Qxc8 48. Qd2 Bc5
{Giving up the knight to allow the king to go to h7 without being immediately
forced back by Ng5+ etc., but this sacrifice does not effect the outcome of the
game.}
49. Nxc5 Kh7 50. Ne4 Qc7 51. Ng5+ Kg8 52. Ne6 fxe6 53. dxe6 Kh7 54. b6 Qc8 55.
e7 1-0
[Event "05CMXD1.0vJunior 6"]
[Site "Riverdale"]
[Date "2005.09.04"]
[Round "6.1"]
[Result "1-0"]
[ECO "A09"]
[BlackElo "2451"]
1. Nf3 d5 2. c4 d4 3. g3 g6 4. e3 c5 5. exd4 cxd4 6. d3 Nc6 7. Bg2 Qa5+ 8. Nbd2
Nf6 9. O-O Bg7 10. Nb3 Qb6 11. Re1 Bg4 12. h3 Be6 13. Ne5 Rc8 14. Nxc6 bxc6 15.
a4 c5 16. a5 Qa6 17. Qe2 O-O 18. Bf4 Rfe8 19. Be5 Bh6 20. g4 Nd7 21. Bg3 Bg7
22. Qf3 Rf8 23. Bf4 Kh8 24. Re2 Rg8 25. Qb7 Qxb7 26. Bxb7 Rcd8 27. Bc6 Rge8 28.
Rxe6 !!
{Junior expected 28.Bxd7 Rxd7 when it is still in the game, although
white should still win on the queenside.}
28... fxe6 29. Bc7 e5 30. Bxd8 Rxd8 31. Bxd7 Rxd7 32. Nxc5 Rd8 33. b4 Rc8 34.
Ne4 Kg8 35. b5 Rb8 36. Rb1 Kf7 37. c5 Ke6 38. b6 Kd5 39. bxa7 Ra8 40. Rb7 Kc6
41. a6 Bf6 42. g5 Bg7 43. Nd2 e4 44. Nxe4 Be5 45. Rxe7 Bf4 46. Rxh7 Kb5 47. Rb7+
Kxa6 48. c6 Ka5 49. Nc5 Bd6 50. Ne6 Ka6 51. Rd7 Be5 52. Rd5 Rc8 53. Rxe5 1-0
The exclams, queries, etc., are mine. I think it would be difficult to tell that
engines were playing the above games and not humans.
>I am
That can be done, although it is best done with engines that have changable
parameters, such as values for center control, piece/pawns values, mobility,
combinations, etc., rather than in Fritz or cousins "handicap" modes and the
like. There the results tend to be to extreme, with the engine making a childish
blunder by poitching a piece or two, then playing like a GM, and so on. It
requires a finer touch. Other than that, there are numerous free engines that
are simply "weaker" than the other engines. For example, BamBam may give you a
good game, or Doctor? 3.0,. And a number of both uci and wb engines.
Ok.
I disagree with you on this. It is true that chess is 99% or so tactics. It is
also true that these engines seldom make tactical errors, at least within the
first move or two. But for an overall plan, and recognition, you still need a
human to advise or suggest what would be a goal to shoot at. For instance, 3 - 4
months ago I was playing with a weak chess player, and during one game, late in
the middle game, I mentioned that she should take care of her bishop and not let
me exchange it since her one passed pawn queening square was the same color as
her bishop. Now, any reasonably competent player would know that all other
things being equal, that bishop gains in significance as the pawn moves closer
to that square, where a computer engine cannot tell you that at some point in
the undefined future a piece's value may be more than it's current value.
It is true, also, that as you say, "There was a time when a GM or strong IM
could poke fun at chess engines," but that time is certainly over, and has been.
> I have a position from one of my games, where I beat a much-higher rated
Ummmmmm....how long have you let Shredder work on it? If the entire line was
forced, Shredder may be able to find the line given enough time. Do you have the
game score handy?
>What do you think?
That is a hard question! Think I'll pass - I would prefer to combine both. I'll
tell you one thing that has surprised me the most, I think. If you look at the
analysis of old tournaments by the old masters, for example St. Petersburg,
1909, or Nottingham, 1936, and so on - the ones that have good game annotations,
it has surprised me how often some of the top engines, such as Fritz 6, 7, 8,
and others, offer the same tactical suggestions as the old masters did. I don't
know if it is that the engines offer the same lines that the masters did, or
vice versa.
about:
[Site "Riverdale"]
[Date "2005.09.04"]
[Round "2.1"]
[Result "1-0"]
[ECO "C48"]
[BlackElo "2451"]
game.}
e7 1-0
[Site "Riverdale"]
[Date "2005.09.04"]
[Round "6.1"]
[Result "1-0"]
[ECO "A09"]
[BlackElo "2451"]
Rxe6 !!
>I am
Ok.
game score handy?
>What do you think?
vice versa.
Hi!
"Angelo DePalma"
Shredder 9? Or Shredder 7? or 7.04?
Do you used TBS?
Regards
SoloMoon
Hi!
"Angelo DePalma"
Do you used TBS?
Regards
SoloMoon
It's Shredder 7 under the Fritz UI (I bought it as such from ChessBase).
What's a TBS? Table base? In the case I mentioned, Shredder screwed up with
about 12 pieces/pawns on the board. By the time they were in table base
territory Shredder was lost.
I don't believe in using TBs in engine-engine matches. It's cheating!!
They're playing engines, after all. Let 'em play.
Angelo
"Solomon Nuffert" <snuff@vmail.ru> wrote in message
news
fi0gl$ebr$1@serv3.vsi.ru...
> Hi!
> "Angelo DePalma"
> Do you used TBS?
> Regards
> SoloMoon
Angelo
news
fi0gl$ebr$1@serv3.vsi.ru...> Hi!
> "Angelo DePalma"
> Do you used TBS?
> Regards
> SoloMoon
Here is the position with White to move in DePalma (1860) vs. Fernandez
(2139):
W: Ka2, Qb3, pc5, pg5
B: pa5, Qc2, pf7, pg6 and Black has just moved his Kh7-g7, which loses by
force.
My Shredder 7 has been analyzing this position for 4 minutes now and gives
the evaluation as -0.44.
Now move 63. Qb2+ and see what Herr Shredder says. Mine initially jumps to
a -2 evaluation, but after about 20 seconds says White is winning. If B goes
over to the Q side via f8 W captures on a5 and defends c5. The threat of
queening that pawn wins the game. If black tries ...f5 at any point (which
my opponent did after moving his king) he loses just as badly.
Players as bad as me hardly get to play interesting endings like that (or
play them well). I'm proud of that game because I noticed the f7 pawn in the
way and that I'd be able to outflank my opponent in all variations (or
simply queen).
Angelo
news
05ph15dom89me8sdll638164jchiq9m42@4ax.com...
> something
> about:
> couple
> [Site "Riverdale"]
> [Date "2005.09.04"]
> [Round "2.1"]
> [Result "1-0"]
> [ECO "C48"]
> [BlackElo "2451"]
> 8.
> h6
> cxd5
> Rc4
> Rf8 40.
> Rc8
> immediately
> of the
> game.}
> 55.
> e7 1-0
> [Site "Riverdale"]
> [Date "2005.09.04"]
> [Round "6.1"]
> [Result "1-0"]
> [ECO "A09"]
> [BlackElo "2451"]
> Nbd2
> bxc6 15.
> Bg7
> Rge8 28.
> Rxe6 !!
> 34.
> Kc6
> 47. Rb7+
> 1-0
> tell that
>>I am
>>would
> changable
> mobility,
> the
> childish
> that
> you a
> Ok.
> It is
> the
> need a
> 3 - 4
> late in
> not let
> color as
> closer
> in
> IM
> been.
> was
> have the
> game score handy?
>>What do you think?
> I'll
> the
> Petersburg,
> annotations,
> 8,
> don't
> or
> vice versa.
(2139):
force.
simply queen).
Angelo
news
05ph15dom89me8sdll638164jchiq9m42@4ax.com...> On Sun, 4 Sep 2005 23:56:43 -0400, "Angelo DePalma"
> something
> about:
> couple
> [Site "Riverdale"]
> [Date "2005.09.04"]
> [Round "2.1"]
> [Result "1-0"]
> [ECO "C48"]
> [BlackElo "2451"]
> 8.
> h6
> cxd5
> Rc4
> Rf8 40.
> Rc8
> immediately
> of the
> game.}
> 55.
> e7 1-0
> [Site "Riverdale"]
> [Date "2005.09.04"]
> [Round "6.1"]
> [Result "1-0"]
> [ECO "A09"]
> [BlackElo "2451"]
> Nbd2
> bxc6 15.
> Bg7
> Rge8 28.
> Rxe6 !!
> 34.
> Kc6
> 47. Rb7+
> 1-0
> tell that
>>I am
>>would
> changable
> mobility,
> the
> childish
> that
> you a
> Ok.
> It is
> the
> need a
> 3 - 4
> late in
> not let
> color as
> closer
> in
> IM
> been.
> was
> have the
> game score handy?
>>What do you think?
> I'll
> the
> Petersburg,
> annotations,
> 8,
> don't
> or
> vice versa.
On Mon, 5 Sep 2005 20:35:10 -0400, "Angelo DePalma"
about:
>(2139):
>force.
There is a problem with the set up as given above: Black's queen cannot be on c2
since white is in check. So, first question: where is black's queen? I tried
putting the queen on c7 and below is a sample with white to move:
(First time I tried my CMX settings in analysis mode. Interesting in that I also
would have chosen 1.Qb6 on a very fast look, but I quickly came to the
conclusion that 1.Qb6 only draws.)
New game,
8/2q2pk1/6p1/p1P3P1/8/1Q6/K7/8 w - - 0 1
Analysis by CMX Dayffd 1.1:
1.Qb6 Qh2+ 2.Kb3 Qg3+ 3.Ka4 Qf4+ 4.Kxa5 Qxg5 5.Ka6 f5 6.c6 Qg2 7.Kb7 Kf6
= (0.23) Depth: 11 00:01:37 11086kN
New game,
Analysis by CMX Dayffd 1.0:
= (0.23) Depth: 11 00:01:39 10975kN
New game,
Analysis by CM9000 Slayer:
1.Qc3+ Kf8 2.c6 Ke7 3.Qf6+ Ke8 4.Kb3 Qb8+ 5.Kc4 Qb4+ 6.Kd3 Qb3+ 7.Kd2 Qb4+ 8.Kd1
Qb3+ 9.Kc1 a4 10.Qh8+ Ke7
+/= (0.31) Depth: 10 00:02:07 2625kN
New game,
Analysis by Chess Tiger 15.0:
1.Qb6 Qe5 2.c6 Qd6 3.Qb2+ Kf8 4.Qc3 Qc7 5.Kb3 Ke7 6.Qf6+ Kf8 7.Kc4 Ke8 8.Kb5
= (0.06) Depth: 13 00:02:15 14079kN, tb=136
New game,
Analysis by Fritz 8:
1.Qb6 Qh2+ 2.Kb3 Qe5 3.c6 a4+ 4.Kxa4 Qa1+ 5.Kb5 Qf1+ 6.Ka4
= (0.00) Depth: 13/37 00:01:01 28426kN, tb=199
New game,
Analysis by Gandalf 6.0:
1.Qb2+ Kf8 2.Qh8+ Ke7 3.Qf6+ Ke8 4.c6 Qg3 5.Qh8+ Ke7 6.Qf6+ Ke8
= (0.00) Depth: 13/40 00:03:06 7114kN, tb=10848
New game,
Analysis by Hiarcs 9:
1.Qb6 Qf4 2.c6 Qc4+ 3.Kb2 Qe2+ 4.Ka3 Qd3+ 5.Ka4
= (0.04) Depth: 12/34 00:01:13 12392kN, tb=2661
New game,
Analysis by Junior 9:
1.Qb6 Qf4 2.c6 Qc4+ 3.Ka3 Qd3+ 4.Ka4 Qc4+ 5.Kxa5 Qa2+ 6.Kb4 Qb2+ 7.Kc5 Qf2+
8.Kb5 Qe2+ 9.Kb4
² (0.58) Depth: 14 00:00:29 19007kN, tb=3399
New game,
Analysis by Shredder 7.04:
1.Qc3+ Kf8 2.Kb3 Qc6 3.Qxa5 Qd5+ 4.Kb4 Qxg5 5.c6 Qd2+ 6.Kb5 Qb2+ 7.Kc4 Qc2+
8.Kb5 Qb1+ 9.Kc4 Qf1+ 10.Kc5 Qf5+ 11.Kb6 Qh3 12.Kb7
= (0.03) Depth: 13/33 00:01:00 11847kN, tb=16623
New game,
8/2q2pk1/6p1/p1P3P1/8/8/KQ6/8 b - - 0 1
1...Kf8 2.Qh8+ Ke7 3.Qf6+ Kf8 4.Qh8+ Ke7 5.Qf6+ Kf8 6.Qh8+ Ke7
= (0.01) Depth: 15/37 00:01:14 15497kN, tb=24721
New game,
1...Kf8 2.Qb6 Qf4 3.c6 Qd2+ 4.Ka3 Qc3+ 5.Ka4 Qc2+ 6.Kxa5 Qa2+ 7.Kb5 Qe2+ 8.Kb4
Qb2+ 9.Ka5
= (0.00) Depth: 15 00:00:30 26695kN, tb=6034
New game,
1...Kf8 2.Qh8+ Ke7 3.Qf6+ Kf8 4.c6 Ke8 5.Kb3 Qb6+ 6.Kc2 Qb5 7.Qh8+ Ke7 8.Qf6+
Ke8
= (0.00) Depth: 12 00:01:05 7553kN
New game,
1...Kf8 2.Qh8+ Ke7 3.Qf6+ Kf8 4.c6 Ke8 5.Kb3 Qb6+ 6.Ka3 Qb4+ 7.Ka2 Qc4+ 8.Ka3
Qb4+
= (0.00) Depth: 14/34 00:00:22 10452kN, tb=148
about:
>(2139):
>force.
New game,
New game,
New game,
New game,
New game,
New game,
New game,
New game,
8.Kb5 Qe2+ 9.Kb4
New game,
New game,
New game,
Qb2+ 9.Ka5
New game,
Ke8
New game,
Qb4+
So sorry. The White K is on a3, not a2.
Angelo
news:ut2rh1t5ibkjoa36jjpv7pm0i4afcfleiv@4ax.com...
> something
> about:
>>(2139):
>>force.
> on c2
> tried
> I also
> New game,
> New game,
> New game,
> 8.Kd1
> New game,
> 8.Kb5
> New game,
> New game,
> New game,
> New game,
> Qf2+
> 8.Kb5 Qe2+ 9.Kb4
> New game,
> Qc2+
> New game,
> New game,
> 8.Kb4
> Qb2+ 9.Ka5
> New game,
> 8.Qf6+
> Ke8
> New game,
> 8.Ka3
> Qb4+
Angelo
> something
> about:
>>(2139):
>>force.
> on c2
> tried
> I also
> New game,
> New game,
> New game,
> 8.Kd1
> New game,
> 8.Kb5
> New game,
> New game,
> New game,
> New game,
> Qf2+
> 8.Kb5 Qe2+ 9.Kb4
> New game,
> Qc2+
> New game,
> New game,
> 8.Kb4
> Qb2+ 9.Ka5
> New game,
> 8.Qf6+
> Ke8
> New game,
> 8.Ka3
> Qb4+
On Tue, 6 Sep 2005 12:31:37 -0400, "Angelo DePalma"
about:
>Angelo
No problem. The black queen is on c2?
I'll have to come back to this in a couple of days...
Have some medical stuff to take care of.
about:
>Angelo
Yes, the W K is on a3, B Q is on c2.
news:ghluh1p1ts82ognl2p99akj9ufg3nknkm4@4ax.com...
> something
> about:
>>Angelo
> something
> about:
>>Angelo
Related ressources:
- ForumUnreal Tournament on Mandrake 10.0 ( LINUX )
- ForumR8500 rules in UT2K3!
- Forumwhere do you buy games online?
- ForumWhere does gatherer store its info?
- ForumWHERE is GTA EFLC Saved games !
- ForumWhere does the GBA store its scores?
- ForumWhere can I find an actually good online wedding dress game ?
- ForumWhere to store Game program
- ForumWhich to use for what? What to store where ? Standard and SSD Hybrid.
- ForumWhere can you buy pc games
- ForumPS3, and Wii adding to wired network.
- Forumrec.games.go
- Forum2 000 000 games
- Forumnew PGN site - million games by ECO code
- ForumPGN games by ECO code
- More resources
Read discussions in other Video Games categories
