I'm looking for a battery operated converter to track some
production demos while I am out and away form any sources of power. I
am using a portable battery operated mixer for pre-amps and a Mac
laptop with cubase to track. I don't expert or want to pay for
stellar but I want the tracks to be good enough that if I decide to
keep a track it won't be completely out of place with the master
tracks to be recorded later.
Portability, size and cost are the first factors to keep in mind.
Budget is best. I don't want to run off of the computer battery
because it lasts about a second to begin with.
> Ideas?
> Thanks
Tascam US-122 is capable to record stereo programs at the resolution of
24 bits. It's powered via USB so the battery inside your laptop will be
used.
Is not very expensive (about $200, as far i know).
Some other similar USB or FW audio interface may meet your needs.
"Danny T" <justadumbemail@netscape.net> wrote in message
news:1127835913.072684.84100@f14g2000cwb.googlegroups.com...
> Ideas?
> Thanks
> Budget is best.
What kind of digital gozinta does your computer have? And what "budget"
is best? I can't think of a battery powered A/D converter that doesn't
also contain a mic preamp, but if you can stand to lose the mixer or
pad down its output, you might want to check out the offerings as
http://www.core-sound.com. They have a decent preamp/A/D of their own
design that has both coax and optical S/PDIF output, and for less
money, the Deneke InBox, thought it doesn't provide phantom power.
How about the Lavry box? I think it is rated for 20 bits, most of
which are good, and the preamp seems okay although it has no phantom
power.
Denecke makes a portable 20-bit converter, out of which at least 15
bits are good. I found the gain controls very fiddly and very hard
to match, but it has an S-PDIF output and will go into any S-PDIF interface.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Cascade Media, LLC
For All Your Digital Recording Needs
Portland, Oregon USA
(888)336-4643
(503)353-6860
(503)353 6864 -fax
www.cascademedia.net frank@cascademedia.net
The Metric Halo ULN-2 would replace both your preamps and mixer and run
off the Firewire bus in your Mac laptop.
I forget I am chatting with Mr. Technical☺ Yes, I need a few parts
but I simplified it to my level of thinking.
I took a look a M-audio and firebox. I think I will let it stir for a
few days while the customers check clears but I am covered at least. I
didn’t realize there were so many solutions now a day. All of these
toys were more then I was hoping for.
Have you used the Firebox that Frank mentioned? It looks like a good
option since it is all in one box an I can plug it in 12 volt or into
my computer for power. Also, it has phantom, which is a must.
I’m doing a bunch of pre-production work for a company and I am doing
it on my boat that will be out in the Bahamas on vacation. I don’t
like using the inverter because it makes a lot of line noise so the
battery thing is pretty much a must have deal.
I just want to say again – thanks to all of you guy s here. I would
have been searching for hours without this help.
Anything that can be powered with a wall-wart at less than 600mha can be
replaced with a battery pack of C or D cells very easily. Or any cells, but
AA's or 9volt rectangles will drain fast.
In article <1127835913.072684.84100@f14g2000cwb.googlegroups.com>,
justadumbemail@netscape.net says...
>Ideas?
>Thanks
No. Many of these devices require bipolar rails and the way
they get that is an AC step down wall-wart with full wave
rectification and regulation within the device.
Bob
"Things should be described as simply as possible, but no
simpler."
In article <dhg3lr0n1g@enews2.newsguy.com>, arcane@arcanemethods.com says...
right, I was referring to equipment with DC wall-warts. Thankfully AC
wallwarts are much less common, though I know the insufferable Sherman
Filterbank uses one.
>Bob
>simpler."
> A. Einstein
In article <MOK_e.252514$9A2.14146@edtnps89>, Chevdo <chevdo@dont.com> wrote:
Unless, like the RNC, it takes an AC wall-wart. A lot of devices are doing
that now, in order to get bipolar supply rails off a single wall-wart.
It's a cute trick, but really irritating if you want to use anything but the
original wall-wart.
--scott
In article <dhgorf$sh8$1@panix3.panix.com>, kludge@panix.com says...
>original wall-wart.
I suppose that enables them to skimp on the design somewhere else. But hey,
the prevailing attitude of this newsgroup is, if an implimentation is
'scientifically sound', we can't criticize it!
