I’m putting together my first P4 system that I’d like to order this Monday. I’ve chosen the Intel 875 Motherboard with the 3.0 CPU. I’ve also chosen a well ventilated case with extra fans so I don’t think I should not be running into any overheating problems.
My questions are concerning memory. From what I’ve read to date, the memory I am considering in using is the CORSAIR TWINX1024-3200C2 or the TWINX1024-3200LL. (Note: I have never over-clocked a system before but it is something I’d like to get more familiar with doing).
Question 1 – Is over-clocking really worth doing. Will I see a noticeable improvement in my systems performance or should I be looking at going with Intel’s recommended module (anybody knows what the best recommended module is)? The thought here is maybe I should go with the lower and more affordable memory and use the money to get a WD Raptor drive to boost my performance. A second option would be to get the 3.2 CPU. Understand it one or the other, 3.2 and standard memory or 3.0 and higher speed memory. I’m already at my max budget. And something like a drive is something I can add on later but to upgrade memory would not be worth it.
Question 2 – If I install either one of these memory modules, then install my XP Pro and do nothing to my BIOS will I be running in a NON-over-clocked mode or does the system sense the modules and makes chances automatically.
Question 3 – The $275 (retail) TWINX1024-3200LL is to the high side of my budget. Is this the best performing and most reliable module I can get for this price or is there another manufacturer I should be considering (I only buy retail items, no OEM)?
Question 4 – OK, let’s say I go with one of these memory modules. My understanding the biggest problem is overheating if over-clocked. I know how to monitor the system temperatures and have taking care of adding a few fans. What is the basic on changing the settings?
Any help, THANKS
Any help, THANKS
