Tom's Hardware > Forum > Audio > Pro Audio > Sennheiser MKH-804 power and adaptor
Forum Audio : Pro Audio - Sennheiser MKH-804 power and adaptor
Archived from groups: rec.audio.pro (More info?)
I am looking for a power supply and tuchel to xlr adapter for a
Sennheiser MKH-804.
Does anyone know where I might purchase one?
Thanks,
mc
Sponsored Links
You can make the Tuchel to xlr yourself if you know the correct
pinouts--Sennheiser can tell you this. "T" or Phantom power supplies
are made by a number of companies, including PSC, Denecke, Neumann,
etc.. Try Trew Audio or Coffey Sound
for these, they might even have used ones.
Philip Perkins
Reply to Anonymous
In article <1128026964.612673.174310@g14g2000cwa.googlegroups.com>,
>Sennheiser MKH-804.
Sennheiser will sell you a tuchel connector or a cable with one on the
end.
The power supply can be a project box with a 9V battery in it. You
just supply +9V on one pin and get signal off the other pin. Nothing
fancy... you could build one into an Altoids box in an hour.
I probably could sell you an inline power supply that takes button batteries,
but frankly the first time you have to change the batteries you'll wish you
made your own with a 9V.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
There are 665 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
