Archived from groups: rec.audio.high-end (More info?)
Goodmorning,
I have a Eci-3 new version (s.n.: 30027). When i select an input, for
example AUX, and i turn off and then turn on the unit using the MUTE
function on the remote, the AUX input remains selected; but, if i turn off
and then on using the MAIN SWITCH, the new input selected will be CD every
time! It start every time with CD line input selected. Is this OK?
Thanks.
Franco Patrucco
