Problem with SoundBlaster making scratchy noise
Last response: in Components
I just set up a new PC for my cousin with a Sound Blaster PCI... using an Asus A7V266 motherboard. Now it makes scratchy noises whenever playing some type of sound, I have tried both the windows driver and the driver from creative, the driver from creative just made it worse. I am wondering if I am doing somehting wrong here? There is no onboard audio for this motherboard either. Thanks for any help someone could provide regarding this issue.
Also, it won't make scratchy noises if I use something like a Sound Blaster Live! but unfortunatly I don't own one to give him anymore. If someone could help... thanks.
Try a different PCI slot, if that doesnt fix it thats as far as I would go trying.
Another sound card is probably your only option.
I recommend the M-Audio Revolution
I just tell it like it is and some can't handle it. If your experience is different, well congratu-fukulation.
<b>I’M NOT A ATI FANBOY, I’M NOT A NV FANBOY, I’M A STABILITY FANBOY</b>
Ask the community
