Tom's Hardware > Forum > Audio > High-End Audio > What Surround Sound Speakers to Buy ???
Forum Audio : High-End Audio - What Surround Sound Speakers to Buy ???
Archived from groups: rec.audio.high-end (More info?)
I have purchased a Yamaha surround sound receiver & am having a hard
time decideing which speakers to get... I saw the Bose set at Sam's
Club but read some bad things about that set. I did some research on
some PSB speakers & saw bad things also. Is there a good sounding 5
speaker/surround setup + sub-woofer that isn't huge $$ ?? Thanks for
any info!
Sponsored Links
>> any info!
Q: what's your budget, the model of the receiver, and room size?
Also, are there any room considerations that we sshould know about?
ie - must be tiny or wood floors or whatnot.
Reply to Anonymous
Where did you see bad things about PSB? I have a their 5i sub and couldn't
be happier.
Kelly
"Barry" <tunereye@yahoo.com> wrote in message
news:c6i257066u@news1.newsguy.com...
> any info!
Reply to Anonymous
I don't think there is a thing wrong with PSB, actually. Especially if you
are on a budget but still want a great sounding speaker. They beat many
others in the price range - and you can get kitted out with good sounding
speakers for not a lot of dough!
On 4/26/04 7:01 PM, in article c6k4bu0u2i@news3.newsguy.com, "Kelly Coleman"
> be happier.
> Kelly
>> any info!
Reply to Anonymous
On 4/26/04 7:11 PM, in article c6k4um02obb@news2.newsguy.com, "Philip Meech"
<macmeech@adelphia.net> wrote:
> Correction: Phase Technology, not PSB. There is also Dana Audio, Ohm,
> and Fluance in the internet direct market.
Wow - Ohm speakers! Are they still around? Amazing boxes, those speakers -
though not particularly colorless, but amazing sound nonetheless!
Reply to Anonymous
- 0 +
tunereye@yahoo.com (Barry) wrote in message news:<c6i257066u@news1.newsguy.com>...
> any info!
Wow.. thanks for all that info!! My room is about 10 ft by 25 feet, I
have carpet & painted plaster walls, Right now I am using large (early
1990's) JBL speakers for the front & AIWA rear shelf top stereo
speakers for the rear (50W & 16 ohms)My new receiver is a Yamaha
RX-V740. I would like to use this for both music (radio & CD's)
Again... thanks for all the info. Barry
Reply to Barry
Now that we have the room size and construction, and I can look up your
receiver specs (90W per channel into 8 ohms - no mention of what happens
into 4), perhaps we can make some progress. You're going to want
something pretty efficient in a room that size with an amp that size, I
think. Yamaha claims that this is a "High Current" receiver, so it
should drive 4 ohm loads which gives you some more flexibility.
What you don't say is why you don't keep your current speakers. Is there
something particular about the sound you DON'T like? Are you worried
that (shudder!) the speakers aren't all matched up? For a while I had
Soundlab Electrostatics up front and old Vandersteen knock-offs in the
back, and it still made quite good surround sound. I have purchased but
haven't set up the Magnepan set with a Rel subwoofer (it takes finishing
up a good bit of remodeling - don't ask), but that's probably going to
take more amp than you've got.
What do you want to spend? That circumscribes a LOT of choices :=)
-- bt
>>any info!
Reply to Anonymous
>>any info!
What model JBL speakers? It might be better to use the fronts you have
and get matching surrounds.
Reply to Anonymous
It will only drive 6 ohms into all channels. I looked at every last
amplifier on the market under $1500 and only one, the Outlaw Audio,
was capable of 7 channels * 4 ohms.
http://www.outlawaudio.com/holiday-sale.html
Click on the 950B/7100 combo stack. I consider this to effectively
be equivalent to a large receiver.
http://www.outlawaudio.com//products/7100.html
Not even the high-end Denons and HKs will do 4 ohms into all channels.
NAD and Rotel won't either - at least without a LOT more money.
So - that means that Maggies are out of consideration.
Reply to Anonymous
On 4/28/04 12:42 PM, in article %9Rjc.6147$lz5.815033@attbi_s53, "Joseph
7 channels for under $2k is a tall order, though Rotel makes a good 5
channel amp for around/under that, though it is just an amp - no
receiver....
I hear Outlaw is a real bargain and is a very good amplifier.
They are "separates" and yes, you are right in that they would behave like a
large receiver, but all the 'buttery wholesomness' of 2 chassis designs will
be yours with that one!
The NAD's I looked at do 4 Ohms as well as 8 Ohms.... The 7 series of
receivers will as well - check it out.
http://www.nadelectronics.com/av_receivers/
All are rated for 4 and 8 ohm driving all channels simultaneously...
Don't know about Rotel, though I do believe their amps have enough beef.
Outlaw makes a good piece of equipment, I hear, but they are not unique in
their ability to drive 4 Ohms.....
It would be worth a try, though - minding the temperature of the amplifier
when you do, since if it gets hot to the touch as compared to driving higher
impedance loads, you could be dealing with amplfier being too loaded down.
Maggies require a very good amplifier to sound their best, so you might not
want to spend the money on them unless you can get the performance you are
paying for!
Like Thiels, the speakers may perform at a higher game than similarly priced
speakers, they *do* require a bit more current than their competitors, so
you will pay the money for them anyway!
Also, they are revealing enough that if you have a bad recording, they will
reveal it in sharp contrast!
Reply to Anonymous
Actually, the 753 and up will.
Still, that's what - two somewhat affordable choices?
I'm a little amazed that good amplifiers still cost so much. Heaven
help you if you want to get into electrostatics.
Reply to Anonymous
>> think.
I have the same amplifier (in a smaller room, though) with non-exotic
speakers (claimed sensitivity 88 dB) and I haven't yet pushed it above
-30 dB.
According to the manual the two positions of the impedance switch are:
1 - 8 ohms for all the speakers
2 - 4 ohms for the main speakers and 6 ohms for the other 4 channels.
If both A and B main speakers are used the impedance must be double
(respectively 16 ohms or 8 ohms).
http://www.yamaha.com/yec/customer [...] V740_U.pdf
Although the manual quotes "dynamic power" into 8/6/4/2 ohms.
If 6 channels * 4 ohms is enough you have the Yamaha RX-SL100.
(digital (PWM) amplifier). It costs around $500.
http://www.yamaha.co.jp/product/av [...] -sl100.pdf
"Built-in 6-channel original Yamaha digital power amplifier
Minimum RMS output power
(0.9% THD, 1 kHz, 6&)
Front: 70 W + 70 W Center: 70 W
Surround: 70 W + 70 W Surround Back: 70 W
(10% THD, 1 kHz, 4&)
Front: 75 W + 75 W Center: 75 W
Surround: 75 W + 75 W Surround Back: 75 W "
It doesn't have many inputs, though. And its power is low: the total
power consumption is 100W, so the above power is not continuous.
I remember reading that higher models of the Yamaha range don't
have an impedance selector and instead adapt dynamically, but since
the DSP-Z9 doesn't have that feature (and you can only chose 6 or
8 ohms for the main speakers) I am probably thinking of the MX-D1,
which is only stereo and expensive:
http://www.yamaha-audio.co.uk/home [...] /specs.php
http://www.yamaha-audio.co.uk/pdfs/manuals/DSPZ9.pdf
http://www.mat.uc.pt/~rps/
..pt is Portugal| `Whom the gods love die young'-Menander (342-292 BC)
Europe | Villeneuve 50-82, Toivonen 56-86, Senna 60-94
Reply to Anonymous
>>> Is there a good sounding 5 speaker/surround setup + sub-woofer
>>> that isn't huge $$ ?? Thanks for any info!
Probably several. Check for instance the Beta series from Infinity:
http://www.infinitysystems.com/hom [...] ?SerId=BET
Hmm, that series in europe seems to be more extensive:
http://international.infinitysyste [...] ge=ENGLISH
Or B&W entry-level series
http://www.bwspeakers.com/index.cf [...] 0%20Series
http://www.bwspeakers.com/index.cf [...] Series%203
Or Wharfedale:
http://www.wharfedale.co.uk/evolution.htm
If you give a price range, somebody should be able to advise you better.
> Ok... the JBL speakers are model L80T.
http://www.jbl.com/home/products/p [...] kProduct=Y
Recommended Power Amplifier Range: 150 watts
Nominal Impedance: 8 ohms
Woofer: 10" aquaplas
Midrange Driver: 5" high polymer laminate
Frequency Response: 35Hz - 32kHz
Crossover Frequency(ies): 800Hz - 4.5kHz
Sensitivity: 90dB (1 watt/1 meter)
MSRP U.S.: $465.00 each
http://manuals.harman.com/JBL/HOM/ [...] ies-OM.pdf
These speakers don't look bad, so if they don't have any problem
you don't need to replace them, although you might want to use them
elsewhere or have a set with identical speakers.
What you are obviously lacking at the moment is a front center speaker,
so it should probably be your first purchase. For instance if you want
another JBL, they have:
NORTHRIDGE E SERIES EC35 (Beech)
3-Way Dual 5-Inch Center Channel Loudspeaker
MSRP U.S.: $349.00 each
http://www.jbl.com/home/products/p [...] sCatId=CCS
Next you could consider a subwoofer although your JBLs are almost
full-range (at least on paper).
>> & AIWA rear shelf top stereo speakers for the rear (50W & 16 ohms)
> I sure would love to match them
> with other surround speakers. As I said I do have some rear 6 year old
> AIWA shelf speakers for rears now... no center or sub though.
Since your surrounds seem weaker you might want 2 (or 3, since your
Yamaha can use a rear center) bookshelf type speakers.
>> My new receiver is a Yamaha RX-V740.
http://www.yamaha.com/yec/products [...] X-V740.htm
MSRP $599.00. About $500 in the web.
http://www.yamaha-audio.co.uk/home [...] x-v740rds/
I have just noticed that there is a new RX-V750.
http://www.yamaha.com/yec/products [...] X-V750.htm
7.1 + 2 (presence) speaker outputs, automatic (YPAO) speaker configuration,
but it does not yet have i-link (only the DSP-Z9 for now).
> Here's another ?.... I also have a older Harman/Kardon model A 403 amp
> (not hooked up) would it help anything to hook it up?
You could use it. Your Yamaha has pre-out outputs and line-outs ,
which you could connect to a line input on the Harman/Kardon.
In fact, if it is a USA, Canada or Australia model it has "Zone 2"
outputs, intended just for that. See the "Zone 2" page (52) on the
manual (page 56 of the pdf).
This would be useful mainly to have sound on another room, although
you could also use it if you wanted two pairs of main speakers (but
I am not sure if that would lead to an improvement in sound).
If after you update your main speakers you have an extra pair of
speakers, this would be a way to use them to have music in the
kitchen, bedroom or whatever.
Reply to Anonymous
10% THD???
You'll note that the distortion rating for the NAD and
Outlaw Audio amps barely changes at all.
This points do a very poor design in this case.
Reply to Anonymous
Humm... The towers might need to be replaced. They are cheaper
consumer grade stuff. I'd stick with JBL, though, as their
professional lines are very good. Think of it as more of the same.
What's the budget?
Surrounds:
Okay, then the best surround would likely be a JBL 4208.
These are their budget monitors and actually sound quite good.
They are also shielded, so they make good centers.
I have one as a center on my system and it works well.
My advice would be to go with the 4200 series speakers for
the rest of the setup and then when money permits, move to
4400 or simmilar series fronts.
http://www.jblpro.com/pages/recording/4200.htm
Note that the specs are realistic and +/-2db instead of +/-3db,
so they have alot more bass than most speakers.
IMO, they will do exactly what the specs state, whereas many
consumer speakers are obviously measured by someone who
is tweaking the results a bit to be most favorable, then
marketing gets ahold of it. 95-something db efficient speakers
with response that requires a huge cabinet which they
don't have and so on.
Of the two, the 4208 is much better and is only 2 inches wider.
The 4206 is usually only sold in pairs, and doesn't sound as
good as the 4208, so it is a good center channel.
http://www.jblpro.com/pages/recording/4400.htm
These are what I have. They are large bookshelf speakers(ie like
to call them "table speakers". OTOH, they sound superb.
I have a pair of 4410s and 4408 surrounds and I have no need
for a subwoofer.
The 4400s are big heavy tanks. Built like they did back in
70s and 80s for tons of abuse in recording studios.
But, again, it's all based upon budget. The 4200s are low priced,
at about $350-$400 a pair, and the 4400s are in the $600-$900 a
pair range.
Links:
http://www.instrumentpro.com/page/MUO/PROD/JBL4208
$187 each, free shipping. Three are $559.86. They would
match the towers you have for now, and you can get the big
4410s later.
http://www.instrumentpro.com/page/ [...] JBL4408AL1
$299 each. Free shipping.
http://www.instrumentpro.com/page/ [...] BL4410AL-1
$429 each. These beat most under $1500 speakers. But they
aren't wood-grained and so on(all meat, no glitz).
http://www.instrumentpro.com/page/ [...] BL4412AL-1
$629 each. IMO, the 4410s are better. They have tighter
bass, play a bit louder, and are vertically aligned, so that
they can easily work as towers.
$560 for surrounds and $858 for the big fronts. But $1400
may be out of your budget, even after you sell your towers
for a few hundred dollars, which is why I mentioned the
incremental approach.
Reply to Anonymous
On 4/29/04 12:32 PM, in article F6akc.16637$lz5.1349697@attbi_s53, "Rui
>>> think.
> -30 dB.
-30dB with reference to what?
Ah - the switch probably drops the voltage to the finals to keep the power
dissipation down - it will likly reduce the amount of power otherwise
available into those loads, and extend the life of the receiver.
Reply to Anonymous
On 29 Apr 2004 22:47:53 GMT, Joseph Oberlander
>10% THD???
It's a 6-channel amp for $500! What do you expect?
Stewart Pinkerton | Music is Art - Audio is Engineering
Reply to Anonymous
- 0 +
True, and I've noticed that they spec the output power at one frequency
(usually 1khz) instead of the standard 20hz - 20 khz and the power should
theoretically double into as 4ohm load. keithw...
"Joseph Oberlander" <josephoberlander@earthlink.net> wrote in message
news:c6s0mp01kg5@news1.newsguy.com...
> 10% THD???
Reply to KeithW
It should almost double in a linear design - but other factors may rear
their ugly heads to prevent a full doubling (power supply, dissipation,
etc.).
On 4/30/04 12:19 PM, in article L0vkc.3503$0H1.384482@attbi_s54, "Keithw"
>> 10% THD???
Reply to Anonymous
> etc.).
IME, I find that a 150% increase is more common outside of
true high-wnd components and maybe twice the distortion.
Reply to Anonymous
I have the Gallo system, 5 tiny sats and a powered subwoofer. It is
much better than the Bose. He has a new package system coming out this
month. Here is a link to what I have:
http://www.roundsound.com/hometheatersystem.html
Ken
In article <c6i257066u@news1.newsguy.com>, Barry <tunereye@yahoo.com>
> any info!
Reply to Anonymous
On 4/30/04 12:19 PM, in article E0vkc.3502$0H1.384505@attbi_s54, "Stewart
>> 10% THD???
Would hope that no one would bring it to a Clarke Challenge, then - :-)
Seriously, though, even for $500, you should be able to do better than 10%
THD!
I was hoping it was a typo and it was 1.0% rather than 10.0%!
Reply to Anonymous
>>> 10% THD???
Not a problem - just make sure that it's held below 50 watts or so, as
the challenge allows.
>THD!
That's a totally irrelevant comment, as you can specify maximuim
poower at 10% distortion for *any* amplifier. All it means is that the
amp is right on the edge of clipping at this point. A more interesting
figure would be how much power you can get out of this amp at 0.1% THD
into 4 ohms - I suspect it's a lot less than 75 watts!
That *is* one of the more relevant ways to compare power outputs, but
you hardly ever see it quoted for 'mainstream' amps - and of course
*never* for SETs..................
Reply to Anonymous
About the Yamaha RX-SL100 ($500 digital (PWM) amplifier):
>>> 10% THD???
> THD!
How about:
Total Harmonic Distorsion (20Hz-20kHz, CD) 0.04% (35W/6 ohms)
This is as low as the 1400/2400 range, and lower than the 440/740
range (0.06%), but at a lower power.
Yamaha seems to have some strange habits about reporting power.
Theirs subwoofers are also specified at 10% THD, which I suspect
is a way to present the highest Watt value they can. But what is
obvious is that this amplifier doesn't give more power into
4 ohm than into 6 ohm. Probably the impedance switch changes the
supply voltage to the output of the digital amplifier ?
This article:
http://www.yamaha.com/yec/products [...] _guide.pdf
has a graph (page 2) which might be useful to understand this,
although a digital amplifier might behave in a different way.
As you see the manufacturer may chose to quote a moderate power
with very low distorsion (0.04% at 35W in the case of the Yamaha
RX-SL100) or an higher power, but with a lot more distorsion
(0.9% at 70 W or 10% at 75 W).
If you check the manual of this amplifier:
http://www.yamaha-service.de/servi [...] L100_m.pdf
you will find a whole bunch of different numbers including one
higher than what I posted above:
" Maximum Power (EIAJ) for Front, Center, Surround, Surround back
1 kHz, 10% THD, 6 & ...................................... 100 W "
Reply to Anonymous
>>>> think.
>> -30 dB.
The volume control on the Yamahas is expressed in dB from -90 dB
to 0dB in steps of 0.5 dB. The -30 dB is about the highest I use
so as not to annoy the neighbours (this morning I was listening
to a music DVD (PCM stereo in 6-stereo* mode) at about that level).
Assuming that Yamaha is not lying that means I still had 30 dB
available (well, maybe a bit less, because my speakers are only
rated for 70 W). Of course, trying to estimate sound level is hard,
but I would think it was about 80 dB, which is consistent with the
speakers specification**.
* 6-stereo is a mode which the Yamahas have in which the 2 stereo
channels are spread to the 5 or 6 available. The rears don't get
much power, but the center front receives a bit, although probably
less than I thought when I wrote the calculations below.
** Order of magnitude calculations: if each front speaker produces
88 dB at 1 W / 1m and the center produces 90 dB at 1 W / 1m,
(this is 1.585 more energy than each front) all three will produce
3.585 more energy, that is 5.5 dB more than 88 or 93.5 from 3 * 1 W.
If one considers a distance from the speakers of 2 m, that is 6 dB
less, 87.5 dB. My amplifier is supposed to have somewhere between
90 W to 110 W*** . Chosing 100 W that would give 107.5 dB. So, -30 dB
would be 77.5 dB, which seems about right.
In a larger room (4 meters from speakers to listener) it would still
give 101.5 dB.
(***differents measures:
90 W is "Minimum RMS Output Power" at 0.06% THD, 8 ohms (20 Hz - 20kHz)
110 W is "Minimum RMS Output Power" at 0.7% THD, 8 ohms 1kHz
130 W is "Maximum Power" at 10% THD, 8 ohms 1kHz
140 W is "DIN Standard Output Power" at 0.7% THD, 4 ohms 1kHz
120/145/185/230 W is Dynamic Power (IHF) at 8/6/4/2 ohms, respectively.
130/160/190/235 W for USA models in the same conditions.)
Since Yamaha doesn't quote a power into 4 or 6 ohms it is not easy to guess.
Hmm, I can't remember if the reviews I read about it have some tests.
I just checked the reviews listed at ecoustics:
http://www.ecoustics.com/Editorial [...] _Name/All/
and none of the three that worked had lab results.
Do transistor amplifiers use output transformers or only valve amplifiers ?
I thought maybe it was a choice of output voltage via a different output
coil (but there don't seem to be output transformers on the amplifier).
Reply to Anonymous
> This article:
This site reprints some bench-test results on receiver performance, including Yamaha
http://www.geocities.com/Area51/Ho [...] tevsac.htm
-S.
"They've got God on their side. All we've got is science and reason."
-- Dawn Hulsey, Talent Director
Reply to Anonymous
There are 1084 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
