Tom's Hardware > Forum > Audio > High-End Audio > problem w/Creek CD43 MkII
Forum Audio : High-End Audio - problem w/Creek CD43 MkII
Archived from groups: rec.audio.high-end (More info?)
I purchased a Creek CD43 MKII last year and have been having
intermittent problems with it. There are certain discs that it just will
not
read, both burned and commercially manufactured. I've had this
experience with other players in the past, but it usually results in a
"no disc" readout on the display and that's the end of it.
With the Creek unit, the disc spins and spins, and then ten seconds
later it just switches into "standby" mode - the power indicator
turns from green to amber and you then have to turn the player back
on to eject the disc.
Does this sound like a malfunction to you?
One of the Creek tech guys claimed that "there is no way of
controlling what the player does when you attempt to play a
media/copy protected disc". I'm just looking for a second
opinion, I guess, or any insights from the group.
thanks much
Sponsored Links
On 6/8/04 6:19 PM, in article ca5e1l01qq5@news2.newsguy.com, "Santos L
> not
Yes it does - but as you said below that copy protectd discs are not Redbook
and Creek players, older ones at least, are noted for this.
I believe the players use CD-ROM drives instead of transports from the major
OEM's.
If it is any consolation, the newer ones play copy protected disks - I don't
know if the Creek players can be retrofitted.
Reply to Anonymous
> not
Definitely. The player should not go into standby mode by itself. Some
players are very picky about CD-R's, and some will not play dirty discs,
but they should not turn itself off.
The tech guy is clueless.
> thanks much
Reply to chung
There are 510 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
