Tom's Hardware > Forum > Audio > High-End Audio > Need rec for small system
Forum Audio : High-End Audio - Need rec for small system
Archived from groups: rec.audio.high-end (More info?)
I am close to buying a condo for summer use. Total size is about 1150
ft^2. My music room at home is about 400 ft^2 -- 15.5x25.5. In it I
run a pair of Apogee Divas driven off a pair of Classe stereo amps. I
need something small that will give me comparable (it could never be
equal) sound in a small space. It also has to be small enough to lock
in a closet if we decide to rent the place. Any ideas?
Sponsored Links
If you like the planar sound, I'd suggest the smallest Magnepans (the
MMGs) about $500 a pair (www.magnepan.com). You can hang them from the
ceiling or wall if you like. For an amp any decent integrated will do,
or the Adcom separates work well. If you're REALLY thinking small, I've
heard good things about the Monsoon speakers, also planar.
(http://peripherals.about.com/library/weekly/aa042900a.htm for an
article and sourcing)
-- Bob T.
Reply to Anonymous
1) Creek, Epos, with subwoofer, Phillips CD Changer
2)Jolida Tube Integrated, North Creek Music Systems also offers kits but
are a bit more expensive.Their Rhythm-Revelator system has also been
very well reviewed.
3)Used Acurus DIA-100 integrated solid state amp with MBOW-1 at
www.shawsound.com.
Reply to Anonymous
Revel Performa M-20
Len Moskowitz PDAudio, Binaural Mics, Cables, DPA, M-Audio
Core Sound http://www.stealthmicrophones.com
Teaneck, New Jersey USA http://www.core-sound.com
moskowit@core-sound.com Tel: 201-801-0812, FAX: 201-801-0912
Reply to Anonymous
There are 1404 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
