MN 500 VPN Problems
G
Guest
Guest
Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
Hi,
I have problems accessing my office VPN. I cannot access
VPN through MN 500 router, I have to directly connect to
my cable modem to get into VPN. Can someone pls help me
configure MN-500 to work with VPN's
Thanks
G
Guest
Guest
This is not typically a problem with the router. Some VPN software will not work with NAT translation (Network Address Translation). This is what allows your to direct traffic to specific computers. What VPN software are you using?
Doug Knox, MS-MVP Windows Media Center\Windows Powered Smart Display
Win 95/98/Me/XP Tweaks and Fixes
http://www.dougknox.com
Per user Group Policy Restrictions for XP Home and XP Pro
http://www.dougknox.com/xp/utils/xp_securityconsole.htm
Please reply only to the newsgroup so all may benefit.
Unsolicited e-mail is not answered.
"VinRip" <anonymous@discussions.microsoft.com> wrote in message news:1e06401c45536$22da8e00$a301280a@phx.gbl...
> Hi,
> Thanks
G
Guest
Guest
You may need to open some ports on the router, most often
port 500, but it depends on the router. Ask the admin
which ports the VPN needs.
>-----Original Message-----
>Hi,
>Thanks
G
Guest
Guest
I am having the same issues. I have a sonicwall VPN
Global Client. I can connect from hotels, airports and
the what not, but at home it shows connected, but never
gives a virtual IP. I tried to use the application
trigger, opening up port 500, but still not luck. Maybe
I missed a step on the application trigger. ANy help
would be appreciated.
using?
Smart Display
>> Hi,
access
to
me
>> Thanks
