Odd mouse problem
Forum Computer Peripherals : Other Peripherals - Odd mouse problem
Here is my problem, and no this is not specific to one mouse, ive tried it on two mice:
When i boot up my computer, half the time the mouse does not turn on at the windows xp load screen. i have to restart and then it works. this is very annoying and i have no idea what causes it because its not specific to one mouse. i think it might be something to do with the mouse socket on the mobo but i have not been able to test the usb as default for the mouse because i my usb mouse broke.
any idea what could be the problem here and a possible solution? Thank you
-lawler
A64 3500+ / K8N Neo2 Plat / BBA 9600pro / 2x512mb HyperX ddr500 / Audigy LS / Samsung 120gb
Wanna buy a Thermaltake XaserIII SuperTower Blk Edition w/ 420w psu UNOPENED, tell me.
Sponsored Links
ive had something similar happen with a mouse, it turned out to be the 5v rail on my mobo was sagging really bad. check your voltages.
this is my boomstick!
Reply to jihiggs
- 0 +
I'm having the same problem. I also have the same mobo and processor. hmmmm. If it is a voltage problem, can it be fixed without replacing the mobo? Or to be more direct, how did you solve the problem?
<P ID="edit"><FONT SIZE=-1><EM>Edited by ARDelta on 12/30/04 11:27 PM.</EM></FONT></P>
Reply to ARDelta
- 0 +
my problem turned out to be one of the mobo contacts on the atx power plug had burned out and began to drop the supply of 5 volts to the mobo very rapidly until the system crashed, i had to replace the burned pin and its working fine to this day. the psu is anyway, ive since replaced the board, its ok too. its developed a few quirks but its fine.
Reply to jihiggs
Tom's Hardware > Forum > Computer Peripherals > Other Peripherals > Odd mouse problem
There are 1234 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
