Archived from groups: microsoft.public.windowsxp.general (More info?)
I did this without planning....
I cleared my harddrive using some freeware from download.com. Now I want to
reinstall windows XP. I have the CD but when I insert into the drive, it
doesn't ask me to boot from the CD. I just get a message saying:
"Error loading operating system_"
I'm not sure where to go from here, please help me if you can =/
Sponsored Links
Your computer may not be set to boot from CD (which it needs to do)
You need to go into the BIOS, to do this, you usually hit F2 or DEL the
moment you switch on your PC.
Reply to mcr
"David" <David@discussions.microsoft.com> wrote in message
news:7173A058-A24F-492C-AA70-88BFC4320705@microsoft.com...
> to
Is your CD set as bootable in the BIOS? Set it to look at the CD before the
hard drive.
Reply to Anonymous
The CD must be set as the first bootable device in your BIOS. Instructions
on doing that should be in the system or motherboard manual.
> to
Reply to Jerry
How do I get to the BIOS to change it? Pressing F2 or Del isn't working =/
By the way, I really appreciate everyone's time for helping me out with this
=D
> > to
> hard drive.
Reply to David
>> > want
>> > to
>> > it
>> the
>> hard drive.
news:58CBC61B-7728-4A04-BCDE-C53C5F8D1BB5@microsoft.com...
> this
> =D
Can you please follow a flow of conversation rather than jump top to bottom
to top please? It makes things easier to follow, and people will be more
inclined to read the thread if they don't have to jump around. And so you'll
be more likely to get help ............
You may need to contact your maker. Or read those booklets that come with
your computer (try the motherboard one). There are several possible ways to
enter the BIOS and it is dependant on your machine. Insert is another common
way, IBM's may need a floppy, etc. etc. ....... Giving the BIOS
make/motherboard may offer clues but there are several ways used, not just
the two you've mentioned, or the two I've added.
Reply to Anonymous
Jumping around? Not following the flow of a conversation? I don't
understand. I real all the replies and posted a reply to them on the bottom
of the thread.
I'm sorry, I don't have any of the manuals or booklets that came with the
computer.
I guess the only clues I can throw are... It's a gateway computer and I
bought it in Sept. 2001. I might have to take it to a computer repair shop,
heh.
> >> > want
> >> > to
> >> > it
> >> the
> >> hard drive.
> > this
> > =D
Reply to David
As soon as you turn on your computer, try pressing F2 or Del continuously,
don't hold it in, just keep tapping it. Normally you'll get to your bios, if
you don't, you'll need to get a hold of the manufacturer of your computer to
find out how to get in there. It may be that you're just missing it. Do you
see anything on the very first screen when you start that says press
something for setup? That would be it.
Good luck
> =D
> > > to
> > hard drive.
Reply to kelly
You might try the Gateway web site, if you can. They have a lot of info on
the older systems and if you use the number on the back they may have all the
info on your specific machine. Your problem is not really too difficult if
you can get into the bios, just be careful to just set the boot sequence to
cd first.
The oldest Geek in the world!
> Good luck
> > =D
> > > > to
> > > hard drive.
Reply to ike
I got annoyed that this wasn't working before. I turned off my computer, had
some lunch, and tried it again when I finished. I don't know why, but it
worked this time. Windows is installing as I am typing this. :P
Thanks everyone, for your help
> Good luck
> > =D
> > > > to
> > > hard drive.
Reply to David
Now I
| > >> > want
| > >> > to
drive,
| > >> > it
saying:
before
| > >> the
| > >> hard drive.
working
with
| > > this
| > > =D
bottom
more
so you'll
with
ways to
another common
not just
news:C417802D-3AFE-4DBB-AAA2-93F07B769A90@microsoft.com...
bottom
| of the thread.
the
| computer.
I
shop,
| heh.
David, there are way to many variables pertaining to the reinstall of a
Operating
system when you have a proprietary system. (Gateway, Compaq, Hewlett
Packard,
Dell etc etc. This is the reason that Microsoft does not support OEM
versions of the
Windows OS. Usually these restore disks just have a boot sector and
point to a
partition on your HDD to restore. If you wiped your drive you are
probably SOL.
Good Luck
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > need help. reinstall xp
There are 1119 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
