Tom's Hardware > Forum > Games General > Games General Discussions > Missing Graph.h and (Graph.lib) woes - any help
Forum Games General : Games General Discussions - Missing Graph.h and (Graph.lib) woes - any help
Archived from groups: comp.lang.c,microsoft.public.games (More info?)
Hi All,
I am trying to compile an old C code written for the Borland Compiler on
the DOS platform. This is a tactical solution and I intend to rip out
the GUI side of things and slap on something like Qt or Tcl/Tk (I'll
also be poting to linux), but for now, i am running out of time and
getting quite desperate.
Does anyone out there know where I can get the header (and also the
associated lib to link it against - I think this is either graph.lib or
graphics.lib). Many, many thanks for any help - and apologies for the
cross posting.
Ann
PS - any help will be appreciated, I have been "googling" all day
yesterday. I got the header (I later found it was the wrong one - but no
luck so far on the library). Please help a damsel in distress ....!
Sponsored Links
Dr Ann Huxtable wrote:
> Hi All,
> the DOS platform.
Which one? If Turbo C, you're in luck, because Borland ship a complete
copy of Turbo C 2.01, from http://community.borland.com/museum/ (you
don't have to pay any money, but I think you have to register, which
again doesn't cost any actual money).
Turbo C ships with the necessary header and library.
If you actually need Borland C, I don't know whether the Borland museum
has a copy of that.
<snip>
Reply to Anonymous
On Tue, 21 Dec 2004 00:29:02 +0000 (UTC), Dr Ann Huxtable
<annhuxtable@research.de.edu> wrote in comp.lang.c:
> Hi All,
> cross posting.
> Ann
You may be in more distress than you know. If you are trying to
compile this code with a compiler other than the Borland one it was
originally written for, chances are that neither the header nor the
library will do you any good.
It is really off topic in comp.lang.c, but Borland has a number of
support groups in the news:borland.public.* family, on their server
nntp://newsgroups.borland.com . They are also accessible from their
web site. I would suggest you post there and provide more specific
information, such as which old Borland compiler it was written for,
and which compiler and operating system you are trying to build it
with now.
Jack Klein
Home: http://JK-Technology.Com
FAQs for
comp.lang.c http://www.eskimo.com/~scs/C-faq/top.html
comp.lang.c++ http://www.parashift.com/c++-faq-lite/
alt.comp.lang.learn.c-c++
http://www.contrib.andrew.cmu.edu/ [...] acllc.html
Reply to Anonymous
> Compiler on the DOS platform. This is a tactical solution and I
> intend to rip out the GUI side of things and slap on something
> like Qt or Tcl/Tk (I'll also be poting to linux), but for now, i
> am running out of time and getting quite desperate.
> the associated lib to link it against - I think this is either
> graph.lib or graphics.lib). Many, many thanks for any help - and
> apologies for the cross posting.
c.l.c is definitely the wrong place to look, since we deal with
portable standard C. If your old C code is old enough you might
find the whole system in the Borland museum. At any rate microsoft
groups are unlikely to pay off, but alt.folklore.computers might.
Also check Borlands own newsserver and their private newsgroups.
Chuck F (cbfalconer@yahoo.com) (cbfalconer@worldnet.att.net)
Available for consulting/temporary embedded and systems.
<http://cbfalconer.home.att.net> USE worldnet address!
Reply to Anonymous
> Hi All,
> cross posting.
> Ann
MAny thanks for your help guys. After browsing the borlang newsgroup, I
decided to take the plunge and simply replace the GUI with GraphApp
(will take a bit longer, but its what I need to do anyway)
Reply to Anonymous
There are 668 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
