Hi I didn't have the time to go throught all of the old posts for the answer to this. So generally for memory you the speed (PC3200, PC4000) and latency (timings 222 232). And for higher speed memory that you buy it generally has higher latency because it is harder to make. However, say I buy CMX512-3200C2PRO XMS3200 512MB 2-3-2-6 and CMX512-4000PRO XMS4000 512MB 3-4-4-8. Clearly one will be able to run faster if I OC my bus/memory. However at the same speed, say 400mhz, which will have lower latencies? Will I be able to set faster timings for the PC4000 or for the PC 3200 and how would I normally know this?
