I just changed the configuration of my computer from P3 733 MHz to P4 2.4 GHz. In the previous motherboard, I was using an ATA100 card to drive the HDDs and the IDE1 port of the motherboard to drive the CDROM and CDRW. The new motherboard (Gigabyte GA-8IPE1000Pro2) has IDE ports with ATA100. So I guess I don't need to use the ATA100 card anymore. But there's a problem. If I connect the HDD directly to the motherboard, the system starts resetting before entering Windows! At present, I'm running the system with the ATA100 card installed. Could anyone please tell me how will I be able to remove the card so that the HDDs can be run from the IDE1 port of the motherboard. Thanks in advance!
