Hello,
I have been experiencing a weird problem since I first bought my computer. When I play any 3D games or applications the screen will turn black (which the monitor loses its signal) for a few seconds, reappear and then turn black again continuously.
This may not look like a RAM problem but when I remove one of the 2 Kingston 256MB RAM stick (I use dual channel configuration which consists of 2X256 MB RAM) the problem mysteriously fixed. But this also cause my computer to lose lots of performance. I have tried to replace it with a new identical RAM but the problem's still the same. It will only be fixed if I remove one of them.
My computer specification:
Intel Pentium 4 2.6Ghz with HT
Asus P4P800 mobo
Asus V9280 Geforce 4 TI 4200-8X
2X256 MB Kingston RAM (dual channel)
40GB hard disk
Anyway I want the dual channel RAM working but not one only. Does any one know how to solve the problem?
Thanks,
Timmy
Asus P4P800 mobo
40GB hard disk
Thanks,
Timmy
