Tom's Hardware > Forum > Smartphones & PDAs > Handhelds General > GPS in the car problem
I have a problem with a GPS Mio 520.
The GPS had a power cable that connects it to the lighter for power input using the GPS mini USB port and it was working.
I lost that power cable and bought another one.
Now when I connect the GPS to the lighter in the car the GPS thinks it's connected to a computer and the GPS stops working, it stuck in a computer mode screen which prevents me from using the GPS.
Is there a way to change something in the cable so the GPS won't go into computer mode when connecting it to the lighter in the car?
Thank you.
Message edited by peteroy on 08-03-2008 at 10:21:15 AM
Sponsored Links
There is no easy way to modify usb cable. I recommend to buy a new one or contact your seller and report the problem.
Reply to mobibarbara
- 0 +
I have a Asus P750 and I have the option to select what connection type I want when it connects to a USB. Maybe if you look you could find the option to turn of computer mode when connected to USB.
Reply to sudec
There are 465 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
