Problems with Realtek HD
Last response: in Windows 7
I've got problems with Realtek driver, when i'm listening to music from wherever (internet, windows media player, etc) a popup appears saying "you have just unplugged a device" and then "you have just plugged a device into the audio jack" intermittently and then sound disappears. I have change my speakers but that was dysfunctional, i have change from Realtek r2.56 to r2.70 and some others and still not working. I have a foxconn motherboard M61PML-K and windows 7 64 bits sp1.
Thanks everyone.
More about : problems realtek
Driver Expert
Windows 7 Expert
been having the same issue with my asus p8z68-v pro gen3 motherboard
really annoying
how to fix
1. open Control Panel, select Hardware and sound.
2. Scroll down and select Realtek HD Audio Manager.
3. Click folder icon just above and to the right of where it says analog back panel and just below device advanced settings
4. click disable auto popup dialog when device has been plugged in
5. Click "OK" twice.
restart pc--this worked for me
either a flaky realtek chip. I can't say about the drivers because I've worked on the ECS H67H2-M mobo and they run on r2.60. no issues. In fact, might just go over and mod the software to run X-Fi MB 2 on them.
really annoying
how to fix
I have done that before, but i still have the same issue. I don't know if it can be the motherboard, because i already look many tutorials and i read lots of forums where people solve their problem with something simple, and i have done the same tutorials in where people have similar problems and my problem isn't solve. Thanks anyway mcnumpty23.
Driver Expert
Windows 7 Expert
have you tried
double clicking on the red speaker icon in the taskbar, and on the window that pops up, click the ā€œIā€ icon.
Just unmark the show system tray icon setting and click ok.
Ask the community
