Tom's Hardware > Forum > Audio > High-End Audio > Problems with DTS 96/24 on Denon AVR-2805
Forum Audio : High-End Audio - Problems with DTS 96/24 on Denon AVR-2805
Archived from groups: rec.audio.high-end (More info?)
Hi All,
I've just bought (and am slowly getting to grips with...) a Denon
DVD-2910 universal player and a Denon AVR-2805 receiver. I've been
feeding them with a selection of CDs, DVD-As, DVD-Vs and SACDs, and on
the whole am pretty pleased with the results.
However, this evening I put on Peter Gabriel's new "Play" compilation
DVD-A, which is one of the first releases to use DTS 96/24. Sure
enough, the receiver indicated it was receiving a 96/24 signal, and
started playing. However, it was playing *extremely quietly* -
according to the Denon's volume control, it was around 30dB below the
volume that was produced by using the external analogue feeds from the
DVD player (which isn't 96/24 compatible).
Turning the volume up to a comfortable level, the amp's volume control
was around the 0dB mark - this is only necessary with this one disc,
only in DTS mode, and only if I use the digital link from the DVD
player. I've tried the disc in my portable DVD player feeding the
digital input on the receiver, and exactly the same thing happens - so
it isn't the DVD player causing the problem.
Has anyone else observed this phenomenon? Is it a) a problem with Mr.
G's use of 96/24 (unlikely), or b) a problem with Denon's
implementation of 96/24 (possible - I suspect it may be common to all
models of this receiver rather than a fault with mine) or c) just the
way Denon have decided to handle 96/24? I've read the Denon manual
from cover to cover and can find no mention of this behaviour - but
then again, Denon's documentation is pretty dreadful, so that doesn't
come as any surprise...
Any advice gratefully received!
Thanks,
Simon
PS Are there any other DVD-As out there which use DTS 96/24 I can try?
Sponsored Links
Simon Long <simon@longnews.freeserve.co.uk> wrote:
> Hi All,
Have you fed it any *other* DTS soundtracks (many movies have them)?
Are they also quiet? If so,
you probably need to calibrate your DTS speaker level settings to match
those of other formats.
Reply to Anonymous
There are 1481 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Latest best answer
Speaker recommendation
By astrallite, 2 days ago:
Try this: Sherwood 5.1 receiver ($172 shipped). http://www.amazon.com/Sherwood-RD6 [...] 05&sr=8-10 Energy Take 5s ($199) http://www.newegg.com/Product/Prod [...] 20take%205 Dayton Sub 80 ($75) http://www.parts-express.com/pe/sh [...] er=300-631 This should come out to $450. As far as Bose goes, unless you are talking about the x01 series from the 70s (which were pretty good back then), their modern speakers are just clock radios designed for decor-conscious older people who need invisible speakers. Acoustically they are no better than your typical PC satellite speakers (I'm being generous here, they are probably worse than high end PC speakers); they really are nothing more than a couple of thin plastic cans. The satellites replacement drivers that you can request from Bose cost $2 (low quality untreated paper drivers) and the satellites themselves are built with thin cheap plastic enclosures. That should give you an idea of build quality...it's basically a product with 95% markup. I doubt their $1000 acoustimass systems cost more than $50 to manufacture. To give you an idea what a value product is, in my bedroom I have a pair of Ascend Sierra 1 bookshelf speakers that go for $800/pair. The tweeters that Ascend purchase from SEAs of Norway cost $200/each, or $400/pair. Include the cost of diamond drill bits for industrial cutting tools needed to cut through 3/4" solid bamboo enclosures, the long-throw injection-molded poly midrange/woofers, and a high gloss piano black automotive finish and you are talking about $600 manufacturing costs. After shipping and handling, I doubt they make more than 25%, a fraction of Bose's margins. It's called name brand markup. That said, it's your money, if you want to buy it, it's your prerogative. And to your room, it's about 11x11 as I understand it? It's not THAT small. I'm running a pair of bookshelf speakers that run 60lbs on 80lbs of solid metal stands and they work fantastic in a 166sq foot office (only slightly bigger than your room).
