Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Remove the "A Network Cable is unplugged" in System tray?
Forum Windows XP : Windows XP General Discussion - Remove the "A Network Cable is unplugged" in System tray?
Archived from groups: microsoft.public.windowsxp.general (More info?)
I have a Network card in the machine that I am not ready to configure. I
will at some point but not right now. I'd like to remove the nag in the
System Tray telling me "A Network Cable is Unplugged." I know it is and
that is what I want. I tried to go into Network connections looking to
uncheck a checkbox to get rid of it but the box that is there to show
Connection when connected is unchecked. How do I remove this nag in the
System Tray? I'd like not change any of the hardware. Thanks.
George Hester
_______________________________
Sponsored Links
If you're not using it you can disable the hardware.
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
| George Hester
Reply to Anonymous
- 0 +
>> configure. I will at some point but not right now. I'd like to
>> remove the nag in the System Tray telling me "A Network Cable is
>> Unplugged." I know it is and that is what I want. I tried to go
>> into Network connections looking to uncheck a checkbox to get rid of
>> it but the box that is there to show Connection when connected is
>> unchecked. How do I remove this nag in the System Tray? I'd like
>> George Hester
If your Control Panel is in Classic view:
Start > Control Panel > Network Conections > right-click on the appropriate
icon for device > select Disable
If your Control Panel is in Category view:
Start > Control Panel > Network and Internet Connections > Network
Conections > right-click on the appropriate icon for device > select Disable
Reply to Stephen
OK thanks Stephen. What is a Network Bridge and how is it useful?
George Hester
"Stephen" <stephen@online.nospam> wrote in message
news:uEYAfUVbFHA.3040@TK2MSFTNGP14.phx.gbl...
> >> George Hester
appropriate
Disable
Reply to Anonymous
- 0 +
Windows XP Home Networking: Building Network Bridges
http://www.microsoft.com/windowsxp [...] ril22.mspx
Reply to Stephen
Go back into network connections. Right click on the network device and
select disable.
"George Hester" <hesterloli@hotmail.com> wrote in message
news:OVt3zuUbFHA.3932@TK2MSFTNGP12.phx.gbl...
> George Hester
Reply to Anonymous
There are 1334 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
