interesting because, in this case, a reviewer (Jason Victor Serinus) who'd
positively reviewed the 'sound' of expensive power cords ($2500 Nordost
Valhalla -- which , he reported, only sounded good after break-in) ,
participated in the ABX, and wrote up the report.
Mr. Serinus had also praised the Bedini Dual Beam UltraClarifier, as sheer
a piece of quackery as ever was marketed to audiophiles.
Even though his acceptance of the scientific method, and the results
obtained thereby, appears grudging at best, I trust that henceforth he
will be more cautious in drawing conclusions about audible difference from
unconctolled sighted comparison.
Archived from groups: rec.audio.high-end (More info?)
Steven Sullivan wrote:
> procedures and results here:
> http://www.hometheaterhifi.com/vol [...] -2004.html >
What the heck was the logic behind expensive power cords anyway? I can't
begin to fathom why, after traveling for miles and miles through wire
that was provided by the lowest bidder, the last three feet would have
some sort of magical difference.
On 8 Dec 2004 00:50:46 GMT, Michael Dombrowski
>> http://www.hometheaterhifi.com/vol [...] -2004.html >>
>Mike
Personally, I don't buy into the "magic" power cord either. But, in
answer to your question, I believe the expensive power cord is only
benificial when used in conjunction with quality grade electrical
outlets, and Power Conditioner.
"What the heck was the logic behind expensive power cords anyway? I can't
begin to fathom why, after traveling for miles and miles through wire that
was provided by the lowest bidder, the last three feet would have some
sort of magical difference."
After having eliminated all of the bits and parts by applying tweeks to
them, powercord wire was what was left. One real area of tweeky audio was
the turntable where individual action might hit upon some previously
unknown trick/technique which addressed it's many inherent sources of
problems in translating mechanical motion into electrical signal. With
the advent of the cd that world collapsed for most audiophiles. I think
one will find that is the era when wire came into the picture as all that
energy was adapted to finding something to replace the previous area where
an individual could make a difference by tweeking a complex system.
You're being too unkind.
This author seems to have conducted an exemplary experiment and been
brutally honest about the result. It's hard to eat humble pie in
public, and to do so is worthy of high praise.
One fault of the article is that it gives time to the "Are Blind Tests
Reliable?" question, which is little more than solipsism. How else
are we to discover whether a blind test is reliable, except with
another blind test? But that is a small fault in the context of the
whole piece.
"Rutgar" <rutgar@mindspring.com> wrote in message
news:cp5tae0cq9@news4.newsguy.com...
>>> http://www.hometheaterhifi.com/vol [...] -2004.html >>>
>>> who'd
>>> sheer
>>> from
>>Mike
There is no reason for any of those things to make a difference. Since it
is well known what the properties of wire are, it is equally well known that
unless one cord is very different in gauge, it will not affect the sound.
Power conditioners are likewise not going to affect the sound, they can only
be useful if your power company or your wiring are not sufficient or tend to
spike.
"Personally, I don't buy into the "magic" power cord either. But, in
outlets, and Power Conditioner."
Do you mean the quality outlets and conditioner mess up the current and
the wire fixes it? This is a variation on the "one needs equipment of
high enough resolution to hear it" school of appology. If the current is
fixed up to the power cord, what fixes it in the many feet in the
transformer after the cord?
Er, where did I say that outlets and conditioners mess up the
current? The original poster asked how an expensive power cord would
make a difference after miles of "lowest bidder" power lines. I
merely said, that the intent is to use the expensive power cord, along
with an "expensive" outlet, and power conditioner. I also said,
that "I" don't really buy into this belief. I was just re-stating
"magic power cord" dogma.
