vinyl noise
Forum Audio : High-End Audio - vinyl noise
Archived from groups: rec.audio.high-end (More info?)
hi everyone, happy new year
i am seeking advice on the best turntable/arm/cartridge (mm)/phono amp to
maximise the
music and minimise all kinds of surface noise - i understand some
combinations of cartridge/arm/turntable show up noise less than others?
my max budget (less is better) is £1000 total either new or s/h
i am replacing a thorens td150mk2 sme 3009 ii (detachable headshell not
improved) and ortofon om20 plus cheap phono box phono amp
any help would be valued
david@dweale.freeserve.co.uk
thanks
david
Sponsored Links
> maximise the
The point of good vinyl playback equipment is to reveal what's
there. Unfortunately, this also includes surface noise. The
best way to attack your surface noise problem is with a combination
of a good record cleaning machine and a good surface treatment.
I have a VPI 16.5 record cleaning machine I like. As for
surface treatments, I've had good luck with LAST record preservative.
Point your web browser at:
http://www.lastfactory.com/
I absolutely guarantee you that using a record cleaning machine
with LAST will make an enormous improvement in your record
listening. Much more than changing turntables, though upgrading
is always fun.
Your current setup will give you some pretty good sound, though
it certainly can be improved upon. Buy the record cleaning
machine and LAST first, then consider upgrades to your record
playback equipment.
Russ
Reply to Anonymous
"Russ Button" <russ@button.com> wrote in message
news:cr19fu0b70@news3.newsguy.com...
to
> > maximise the
> is always fun.
> playback equipment.
> Russ
I can only second this, loud and clear. I have been cleaning my records
since the beginning, and using Last record preservative since it came out.
The result is reduced noise and distortion, and a sound that much of the
time is indistinguishable at normal listening levels from CD as far as
silence is concerned. Moreover, LAST really does seem to help foreclose
wear; some of my records from the 60's and early 70's sound remarkably
"new", despite frequent use.
Reply to Anonymous
>> maximise the
>is always fun.
>playback equipment.
>Russ
I would concur with the recommendation of investing in a record cleaning
machine. I've had my VPI 16.5 for over 10 years, and it does an excellent job,
with no maintenance needs other than an occasional replacement of the suction
wand supplied with the machine.
However, the LAST record preservative, while not harmuful in my experience, is
not IMHO, the last word in cleaning. For that I'd recommend using the Disc
Doctor brushes and cleaning fluid, in combination with a RCM like the 16.5.
You can learn about the Disc Doctor products, which are really excellent (and
I've tried other brushes and fluids with the 16.5, inclujding LAST's own record
cleaning liquids) at the following URL:
www.discdoc.com
While the post to which I'm responding doesn';t specify what
turntable/arm/cartridge you're using, I would recommend you seriously consider
either getting a turntable with a clamp, or if the brand you have does not come
with one, you purchase an aftermarket clamp. Clamping can also help to reduce
surface noise.
Depending on your budget, I'd recommend one of the excellent VPI models, with
one of their tonearms, and perhaps a Grado cartridge. All three items come in
a broad range of prices, and all represent excellent value for the money. If
possible, I'd try and include one of the wooden-bodied Grado cartridges from
their Refernce or Statement series.
Good luck.
Bruce J. Richman
Reply to Anonymous
"Bruce J. Richman" <bjrichman@aol.com> wrote in message
news:cr3u4202b1n@news1.newsguy.com...
> www.discdoc.com
A *miracle* record cleaner; enough said should you believe in miracles, I'd
be more interested into looking for a miracle to restore my hearing to what
it was like 50 years ago. It would be worthwhile to get that record cleaner
into an analytical chemistry lab and transform that miracle into ordinary
everyday household words in order to purchase it from CVS.
Reply to Anonymous
The reviewer who you are probably thinking of is Edward E. Long.
Klaus
michael wrote:
> The old Audio magazine used to sometimes have very good turntable
> reviews using measurements of acoustic feedback, etc, along with
> listening tests. I wish I could remember the reviewers name who
> conducted them. Was it Bert White? Anyhow, the few remaining mags
that
> use controlled tests are probably not interested in vinyl, anymore.
Reply to Anonymous
Here's whay I found on surface noise :
Factors responsible for surface noise are
1. Surface roughness : filler (tends further to chip off. leaving holes
in the groove wall)
2. Welding and shearing of asperities (roughness, harshness)
3. The associated plastic deformation : microscale intermittency of
plastic flow : volumetric version of stick slip behaviour, slipping of
molecular aggregates from one position of equilibrium with their
neighbours to another, discontinuous motion on microscale.
4. Thermal agitation of cutting stylus
5. Lead screw vibration transmitted to cutting head
6. Vibration of stylus induced by frictional drag, stick slip motion
during sliding friction : each asperity (roughness) will first stick,
then progressively experience elastic deformation in shear produced by
the gross sliding motion, until finally the
shear stress becomes high enough to produce a slip either by rupturing
the asperity or by causing the adhering surfaces to separate.
Surface noise sources as mentioned under 1. 5. are physically present
in the groove, 4 and 5 are cut into the groove during cutting the
master lacquer. The cartridge makes no difference between audio and
such noise signals. The slip stick motion as described under 6.,
however, should not be transduced into output voltage. This depends on
the quality of cartridge
design.
[1] Barlow : Limiting factors in gramophone reproduction, Wireless
World, 1957, vol.63, p.228
[2] Hunt : On stylus wear and surface noise in phonograph playback
systems, JAES, 1955, Jan., p.2
To add : In general, the tape used during recording in studio or
concert hall is not used as source for cutting the master lacquer. The
reason is that the length of tape and what can be put on a record's
side have to be the same. Therefore, copies of 1st, 2nd or even 3rd
generation are used for the cutting process. Each analog tape copy adds
some 3 5 dB noise which, of
course, can be found back on the record.
LP wear of course can cause noise : In a study performed by Discwasher
in 1980 it has been found that the quality of the vinyl plays an
important role as far as sound quality is
concerned. In particular the filler material used is of great
importance, it seems that it has tendency to split off. Dust in the
groove is pushed and pounded into the groove wall, scouring and gouging
the wall.
Klaus
Reply to Anonymous
Tom's Hardware > Forum > Audio > High-End Audio > vinyl noise
There are 1106 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 bew1075k won the Uniformed badge
  • 01:00 Parasitic won the Uniformed badge
  • 01:00 X3no won the Uniformed badge
  • 01:00 Siq won the Uniformed badge
  • 01:00 wayspooled won the Uniformed badge
  • 01:00 chris62 won the Freshman badge
  • 01:00 Tattysnuc won the Freshman badge
  • 01:00 gamerk316 won the Freshman badge
  • 05:23 jsc won the Overclocking badge
  • 01:00 rolli59 won the Spy badge
