Tom's Hardware > Forum > Audio > High-End Audio > NAD tuner LEDs gone... Replacement?
Forum Audio : High-End Audio - NAD tuner LEDs gone... Replacement?
Archived from groups: rec.audio.high-end (More info?)
I've got a NAD 4130 tuner that has served me well for many years.
Still sounds solid. But the 7 segment LEDs for the tuner display have
several dead segments. Does anyone know the part number or specs for
replacement LEDs?
Much obliged.
Sponsored Links
If it is not the series current limit resistors (could be either discreet or
resistor network), you should be able to find a suitable replacement at
Digi-Key. You just need to match the part number of the display and make
sure that the brightness letter code matches on all of the units on the
replacement set. It will be a letter from A to E, etc. Don't worry if it
doesn't match the brightness code on your current units, as long as you
replace all of them.
Pete
"Dr. Dagor" <drdagor@hotmail.com> wrote in message
news:cujjp102raj@news1.newsguy.com...
> replacement LEDs?
> Much obliged.
Reply to Anonymous
There are 540 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
