CeBIT 2008: New CPU and Water Coolers from Thermaltake
G
Guest
Guest
If you need good cooling performance but one cooler just isn't enough, there is an obvious solution - just take two instead. It seems that is what Thermaltake's engineers must have been thinking when they came up with the DuOrb CL-P0464 cooler. It consists of two coolers stemming from the Orb series that are connected to the CPU cooling block via heatpipes.
CeBIT 2008: New CPU and Water Coolers from Thermaltake : Read more
