Tom's Hardware > Forum > Smartphones & PDAs > Windows Mobile > Screen Alignment Samsung Omnia Problem
Forum Smartphones & PDAs : Windows Mobile - Screen Alignment Samsung Omnia Problem
I have a Samsung Omnia handset in which Screen Alignment refuse to work after I carried out a hard reset. Taking it to a service centre, I was told that I may need to change the touchscreen. Can you please help me to sort out this problem since I am not sure that the touchscreen have any problem.
Sponsored Links
Hi Segun, what do you mean by refuse to work? It won't start or nothing happens after you set the screen alignment?
Also, check if your screen is properly positioned on your phone (no gaps between the phone and the touchscreen, etc.).
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
Hi All, What he means is that no matter how many times he accurately touches the target on the Screen Alignment display, the screen will not calibrate and continuously recycles back to the first target. This is a common problem with these phones and to my knowledgem there is no fix except to continuously try to calibrate the screen over and over again until you get lucky enough for the calibration to be satisfied and then continue with the phone start up. BTW This problem doesn't only happen when the phone is hard reset. In fact, a lot of people hard reset the phone because the Windows Mobile screen calibration (under Start -> settings -> System Tab -> Screen) has the exact same problem and the screen never calibrates. However, once the phone is Hard Reset, the owner is forced to complete the screen calibration which will almost never complete.
Two months ago I was lucky enough to get my screen to calibrate after 30 minutes of hitting the target right on the nose. Two months later, the touch screen is out of calibration again, and even though I ran the "Align Screen" in accordance with all know instructions, one hour later the process has still not completed. Now I know that someone is going to say that my touch screen is probably bad. Nope, took the phone to Verizon Wireless and they agree that the phone is actually working fine but the "Screen Align" program just doesn't work on these phones once they have been in operation over 3 months (or so). Love the rest of the phone, hate the screen alignment problem and will never own another Samsung as a result. Some day someone will make a Smart Phone that works as good as a iPhone or Balckberry but *isn't* a iPhone or Blackberry. That will be the next phone for me.
Reply to Anonymous
There are 1277 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
