Archived from groups: microsoft.public.windowsxp.general (More info?)
Greetings. I have a Win2k installation that's fine, but I need to install
XP in order to run some games. I've heard that XP is respectful of Win2k if
you install XP last. However, when I installed xp -- putting it on its own
small partition -- selecting Win 2k from the boot options prompted a missing
file message. XP would load ok.
I've looked around and it seems that the solution is to keep the XP-produced
boot.ini file, but replace the ntldr and ntdetect.com files that XP
installed with the same files from the pre service pack 1 XP. I've done
this and it seems to work. Is this the best solution? Am I running any
risks? Thanks.
risks? Thanks.
