Tom's Hardware > Forum > Audio > High-End Audio > John Bowers Active One Speaker Problems
Forum Audio : High-End Audio - John Bowers Active One Speaker Problems
Archived from groups: rec.audio.high-end (More info?)
Hello,
I recently acquired a pair of John Bowers Active Ones,
serial number 359 and 360. Made in 1985.
They have an internal 300W Mosfet amp.
So I get them home, plug them in, run an RCA jack from
my preamp and get nothing - no sound at all.
One the back, they both have one small red light, and one small green
light, both are on.
When I first turn them on just the red light is on, then I turn it off,
turn it back on a litle bit later, and they are both on.
1) I open the case and look at the amp boards and it looks like the
preamp board (tone control I guess) has a small black smoky looking
spot, so I'm assuming it's fried?
2) The power supply says 220V, and it was sold originally in Germany,
could it be a power supply problem? Could US power have fried the amp?
It uses a computer style three prong AC cord.
I ran the speaker connectors out the back and through an external
crossover and all the drivers are working perfectly and sound great
with my tube amp so it's not a problem with the drivers.
All the fuses are fine.
Any help or suggestions would be greatly appreciated.
Thanks,
Mike
Sponsored Links
On 4/16/05 10:46 AM, in article d3rc0p01em5@news4.newsguy.com,
Hard to say. If anything was fried, chances are it would be on the power amp
board. To an untrained eye, lots of things that look fried, aren't.
This is at least one of your problems, and hopefully the only one. You need
to contact B&W and find out how to get them rewired for 120volt operation.
It may be as simple as moving a fuse, or as complicated as replacing a
transformer. This is not something you should fool with on your own. It is
highly unlikely you did any damage by plugging them in to too low a line
voltage.
> Thanks,
> Mike
Reply to Anonymous
There are 1158 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
