Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Sound Problem with Toshiba Satellite A70! Please help!
Forum Laptops & Notebooks : General Laptops & Notebooks - Sound Problem with Toshiba Satellite A70! Please help!
Hi guys!
I recently formatted my friends Toshiba Satellite A70 notebook. I used Win XP Pro with Service Pack 2, everything was going fine, i installed the necessary drivers that were included (with the exception of the mobo drivers i'm pretty sure) to avoid unwanted extra notebook bullshit that everyone has starting out. Next I installed the audio drivers for I guess what would be onboard sound? It's Realtek AC'97 drivers. Once they didn't work I went on their website and got the latest release from them, installed those and still nothing.
Can anyone help me out with this? I DO remember hearing something about sound conflicts and Service Pack 2 with certain Mobo's, but I don't remember which one's, and I'm not entirely sure what kind of mobo would be in this. I know it's an Intel based notebook, not AMD, I don't know if that helps at all. If anyone can help me with this it would be great. Even if I have to rollback to Service Pack 1 or possibly get further Windows Updates, I've only updated once since I've formatted the computer/installed XP-pro.
Any help on this would be appreciated, thanks guys :)
Edit: I've recently uninstalled the Toshiba Realtek AC97 Drivers, then installed the BIOS Chipset drivers provided by Toshiba, reinstalled the Audio Drivers, and still have the same problem. I hope to christ I'm not going to have to reinstall all this **** again. Can someone please help me out with this?[#ff5500][/#ff5500]
Sponsored Links
If you don't have any warnings, i.e., red or yellow symbols, in Hardware Manager, check the audio software settings to make sure nothing is set to mute. There should be settings in the Control Panel as well as the software that comes with Realteck
Message edited by g-paw on 09-10-2007 at 10:57:55 PM
Reply to g-paw
- 0 +
Nope, no red or yellow flags in system devices. I think i MAY have installed the drivers in the wrong order. Possibly putting the chipset drivers on after i installed video drivers or other things. That might be it, but i'm not sure.
Reply to varien
- 0 +
Usually you are supposed to install the chipset drivers before the others. You could try to unistall all the drivers and then reinstall starting with the chipset. Take it none of the mute settings are checked.
Reply to g-paw
- 0 +
Yeah, I tried to do that, but i'm not sure which ones i am after reinstalling. I tried a system restore but it's giving me an "incomplete restore" so I'm not sure what to do now. I don't know if I should just re-format everything again...or dare i risk rolling back the Chipset drivers? The bios is flashed so...i dunno if i wanna do that.
That's probably the reason why I can't system restore because of the chipset drivers maybe?
Reply to varien
- 0 +
Clean install would be your best bet if you can't do a repair off the CD'
Reply to g-paw
If you reinstall the OS put them in this order (usually)
Chipset
VGA
Audio
Modem
LAN
Touchpad
PCMCIA & Cardreaders
Wireless
http://www.killernotebooks.com/images/logos/micro_insignia.gif
Reply to killernotebooks
There are 1094 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
