best sound??
Ok so what sound card has the BEST sound? This includes quality and general pleasingness of the sound (IE: The lynx two is the BEST card for recording, but to listen to it it's far too transparent to be particualarly enjoyable) I would like to see several options at differant price levels, and also maybe some reviews of differant cards. I've spent quite a bit of time reading up on differant cards, but would like to hear some opinions of other people :D
01001001 00100000 01001100 01001111 01010110 01000101 00100000 01110011 01110000 01100101 01100001 01110010 01101101 01101001 01101110 01110100 00100001
2 answers Last reply
More about best sound
  1. What sounds best to your ears is the best! Sound is subjective to a great amount and if a sound card doesn't have obvious flaws it's generally your own taste that dictates which one is the best. And how do you know Lynx TWO isn't enjoyable? e.g. overall I myself prefer a transparent sounding solution although a little added warmth helps in some situations.
    I'm not too familiar with each price point but these are the options you have at ~$100: Creative Audigy2 ZS, M-Audio Revolution 7.1, Terratec Aureon 5.1 Sky/7.1 Space, Audiotrak Prodigy 7.1. At <$250 there are Terratec DMX-6Fire 24/96, M-Audio Audiophile 2496, Creative Audigy2 ZS Platinum Pro and [many] others I don't know about (from the likes of M-Audio, Echo and RME) more oriented towards the musicians and home studio folks. You go higher and you reach the likes of M-Audio Delta 1010 with which you can even track drums digitally (multi-track) because of the number of inputs/outputs it provides. And then there's Lynx...
  2. protools HD series
    ASUS A7N8X, xp3200+ (217x10.5, 2.65v), 2xKINGSTON HYPERX PC3500 512MB(217mhz, at 2 3 3 7, 2.6v) segate 120g 8mb ATA100 segate 80g 2mb ATA100, Creamware pulsar2, ATI9800pro 128mb, audigy2zs
Sound Cards Internet Explorer Components
