Archived from groups: rec.audio.high-end (More info?)
Greetings,
At one time, I was immersed in high-end audio, but over the last 10
years, my time has been consumed by other interests. Yesterday, my
beloved Sumo Andromeda III power amplifer blew the left channel rail
fuses on power-up. I replaced the fuses, which again blew immediately
when the amplifier was powered on.
I contacted James Bongiorno, who was kind enough to repond quickly
with the bad news. The MOSFET design of this amplifier evidently
isn't run-of-the-mill, so finding someone competent to fix it would be
tough. More difficult would be finding parts, so I've resigned myself
to the fact that my Andromeda III may have to be laid to rest....
Being away from this hobby for such a long time has left me in the
dark when it comes to new technologies in amplification. The
Andromeda III was a refreshing product in the world of high-end;
high-end performance and power, without the astronomical prices that
seem to plague the hobby nowday's. I'm not one of the fortunate few
than can afford a Pass, Levinson or Rowland product.
In need of a replacement, I started browsing the net to see what was
available. I see the Aragon's, Krell's, Classe's, etc. still aboud,
but I was intrigued by a product from Dutch company Acoustic Reality.
Their eAR amplifier evidently uses digital technology based on
something called ICEpower. I have no clue what this is, so I was
wondering if anyone was familiar with this technology. Does it have
sufficient current to drive complex loads? I recall a friend mating a
Carver magnetic field amplifer with Martin Logan Sequel II's, and the
load killed the Carver amp, despite it's claimed power of 500/wpc. I
wonder about something that can be so small, yet deliver 1000/wpc.
Also, what about so-called "commercial" amplifiers, from companies
such as Crown? I had Crown equipment years ago, and at the time, it
was considered "high-end." How does commercial equipment differ from
the likes of a Krell? Is it simply 5" faceplates made of titanium and
CAD designed heat sinks?
Cutting to the chase, I need a new amplifier to mate with my Sonic
Frontiers SFL-1 pre-amp, powering Von Schweikert VR-4's in a very
large room. The Sumo's 240/wpc fit the bill, so something in this
power range is needed.
Any input/advice/direction would be greatly appreciated!!!! I guess
I'm officially back in the hobby!!
Seadweller wrote:
> Greetings,
>>snip<<
I have used the Counterpoint SA220 with these speakers, but like your
amp, parts are hard to come by and if it blows, well, good luck. It can
be updated by the original designer, but I am not willing to pay the
cost. So, I looked for a solid state amp to fit the bill of driving
these speakers. I found a used Parasound HCA2200 MkII. Wonderful!
"Seadweller" <marbisi@tampabay.rr.com> wrote in message
news6bftg02dbd@news3.newsguy.com...
> Greetings,
The best price/performance ratio I know of in a good sounding high powered
amp is the Outlaw Audio M200 monoblock, sold on the web. They are 200w (8
ohm) and 300w (4 ohm) power amps with excellent, delicate sound when called
for and balls-to-the-wall power when called for. They are slim, rack mount
size and weigh 18 lbs each. They cost $299 ordered directly from Outlaw,
with a 30 day money-back guarantee. They also come up occasionally on
Audiogon used and sell quickly.
www.outlawaudio.com
On 17 May 2005 02:34:54 GMT, TonyP
I support the above recommendation, and would add the Bryston 4B SST.
Lots of good, clean power, and a 20-year warranty. More than adequate
for the excellent VR-4.
Stewart Pinkerton | Music is Art - Audio is Engineering
TonyP wrote:
> Seadweller wrote:
>> Greetings,
> >>snip<<
Odyssey is a company worth looking into. Their Extreme monos would fit
the bill for under $2000 used and Audiogon has a couple of pairs for
sale right now.
I've not listened carefully to Krell, so I can't speak to how good they
are or are not. But as you've asked about commercial amps, I've been
running some of the newer Hafler pro-grade amps and I've been
very pleased with them. They are MOSFET amps and have that
characteristic MOSFET sound, which I personally like.
Pro-grade amps are engineered to withstand abuse, both from
bad signals, difficult loads and poor physical handling, in addition
to poor environmental conditions. They also are typically made
to rack mount. So whatever load you throw at 'em, they should
be able to handle it.
One major flaw with pro-grade amps is that the great majority
of them are fan cooled, which means noisy. VERY noisy. The
Hafler amps are mostly air cooled and have pretty sizeable
heat sinks as a result. I'm very happy with mine and one
nice thing about them is that they cost significantly less than
your typical high-end, Krell or Rowland Research amp.
Try to find a dealer that will let you try out a Hafler amp
before buying it. Or alternately, find one that will let you
purchase it with a right to return it within 14 days or such.
Hafler is a solid product.
Russ Button wrote:
> been running some of the newer Hafler pro-grade amps and I've been
Now I have read your idea about the Mosfet amp or sound a couple of times.
What is the paticular "sound" of a Mosfet amp? How is it different from a
BJT amp? Could you cite some references (other than anecdotical tales)? Is
it possible to measure this characteristic and which kind of measurement is
it?
ciao Ban
Bordighera, Italy
> it?
I have no idea if you can measure it. It's my understanding that MOSFET
transistors, like tubes, distort on even order harmonics, rather than odd order
harmonics like your typical solid state amp. That being the case, they tend
to have a rather tube-like sonic quality. I owned a B&K ST-140 amp for
about 16 years, which was a relatively early MOSFET amp. The Hafler
MOSFET amps I'm running sound very similar.
But like everything else you read here, you have to go listen for yourself
and make up your own mind. Anecdotal tales are really a reflection of
personal experiences, not a scientific sampling. As I said, I like what I
personnally perceive to be a sound characteristic of MOSFET amps.
You have to go listen for yourself.
Sure you can measure such differences. It's a myth that MOSFETS are more
tube like than BJT's. When optimally biased, BJT's produce about he same
spectra of byproducts as MOSFETS, and actually produce less in quantity.
(better linearity) BJT's also have significantly lower output impedance -
an important advantage in amplifier output stages. Also, in general,
MOSFET P channel devices are a much worse match to the N channel devices
than with bipolar devices, which decreases linearity in complementary
circuits.
The main advantage of MOSFETS is better high frequency bandwidth, (somewhat
mitigated by their high input capacitance) and the potential for somewhat
greater reliability, due to the negative temperature coefficient, which makes
thermal runaway less likely. But BJT's implemented with proper design
techniques don't really have that problem in practice. IOW, cheap and dirty
MOSFET output stages are usually more reliable than that counterpart in
BJT's.
> it?
Two factors here in the main:
Mosfets tend to clip "soft" compared to bipolars which clip "hard".
You do run into clipping more often than you may think with the average
<=90dB/1w/1m speaker and even a 200 watt amp.
Secondly, the Hafler amps use a composite current/voltage feedback
method and iirc, current amplification inside the amp circuit, so the
circuit itself is slightly different than the typical amp - I think they
call it "transimpedance" or used to do so.
Mosfets do tend to have a different spectrum of harmonics compared to
bipolars, although in any push-pull design "second harmonics" are going
to be surpressed anyhow. All amplifying devices have a different spectra
of harmonics both in terms of amplitude and order... which is part of
the reason that some people really like the way triodes sound. :- )
In addition a typical Mosfet amp is biased somewhat into class A, moreso
than the typical bipolar amp - although there are exceptions.
Early on there was what was called "mosfet haze" which was due to poor
circuit design, not some aspect of the Mosfet itself.
Merely having Mosfets in a circuit does not assure you of good quality
sound or anything else.
Very informative! A lot of stuff here I didn't know.
Thank you!
Russ
> _-_-bear
Mosfet amps are notorious for having higher distortion then their
BJT's compliment.. Mosfet and Tubes amps >.1% distortion and most
BJT's will give 0.01% easily with standard components...
Special considerations have to be used to get any kind of performance
out of Mosfets. Any manual in Amp design will show you the downfall
of mosfets.. Check out D.Self audio distortion website.. it will give
you a good primer on audio amp design..
Lubbie...
>circuits.
>BJT's.
