Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Sound Problem In Toshiba Sattilite A105-s2081
Forum Laptops & Notebooks : General Laptops & Notebooks - Sound Problem In Toshiba Sattilite A105-s2081
1 in 4 times I consistently when I start my laptop the sound is completly dead, but as soon as I restart is works fine for another 3 reboots. I already tried new drivers, no change in the problem. I have a Realtek Hd audio card. Any ideas? :pfff:
------------------------------ When I die I want to go peacefully in my sleep. Like my grandfather. Not screaming and flailing my arms like the passengers of his car.
Sponsored Links
Help?!?!?!??!?!?!
Reply to gigman
- 0 +
Could try uninstalling Realteck from Add/Remove Programs and reinstalling or try a Windows Repair from the CD if the CD came with the laptop. Also could do a clean install that would first require backing up you data. If none of this works, likely a hardware problem
Reply to g-paw
- 0 +
I tryed everthing but doing a clean install, which will likely fix the problem. I will do that and update this thread as soon as I get my external hard drive.
Reply to gigman
There are 520 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
