Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Laptop Power Jack Problem or loose dc socket.
Forum Laptops & Notebooks : General Laptops & Notebooks - Laptop Power Jack Problem or loose dc socket.
Do you have to fiddle with the power plug on your Laptop to get it to switch on?
Then in the middle of your work it switched off losing all of your work 
for some years now this has provided me with a fair income and a lot
of new and happy friends. After hearing from many of my clients of the despair they have gone through after taking the computer to a repair shop only for the same problem to happen a few months or as little as 2 days after the supposed repair. From this it has given me a hard time to convince people that this won’t happen with my repair so i set up a self help website with some hints and tips to help. www.powerjackrepair.com or .co.uk I likewise hope this can help you and many others. Check out my site.
I Have 100% success rate over 100’s of laptops. Please post comments in this group and i will try to do my best to help. My name is Colin.
Sponsored Links
Hi Colin,
My inspiron 8100 would not power at all (no lights, no nothing). I tore it down and found a LOOSE DC power board. I reseated the board, and cleaned all contacts. I put it back together and it booted right up.
It runs fine using the AC adapter, but it will not charge the batteries. The one battery had 5 green lights and the other battery had 4 green lights when I began. Now they are both discharged and will no longer charge.
I bought a new AC adapter and I still have the same issue.
Does this sound like a bad DC power board?
Reply to ibleet
- 0 +
Sometimes what will happen is the Onboard fuse will blow. the fuse will be surface mount and very close to the battery terminal points, white or yellowish component about 5mm. but do read the component data on the board. Hope this has helped
Reply to carl97
- 0 +
Ops forgot to mention,
The fuse is there to protect the battery
Reply to carl97
- 0 +
Thanks that does help and I will be sure to check that. :)
Reply to ibleet
- 0 +
Remove this thread as its just spam. This guy has no intentions of helping anyone, he just wants to solicit business.
Reply to ibleet
- 0 +
Thats Not true, I know it was a bit cheeky for the first part of the thread
But it does attract the right people with this problem.
If i can help i love to help Notice i am in the UK so most of any jobs i could never accept.
ibleet, have i tried to sell you anything ? No the answer is "NO" i have only tried to help you. The site i list have had many good comments as it guides people through the simple diagnostics of this problem.
I cover this problem not for the money but more so because i feel people have been cheated by the companies that produce these weak computers.
I am out of here, Chillin
Reply to carl97
- 0 +
hello!!! I found very usefull your comments, i hope you keep doing this, its great. I want to ask you, I have a compaq V2000 that does not turn on. It will only turn on the power light and blink some others. I think it is the DC power board, but it is part of the motherboard. Any recomendations? thanks
Reply to serzav
- 0 +
Hi Serzav,
If you have the problem like this:
You switch on and you only get lights and lights switch off and on about 3 or 4 times then switches off it could be the Motherboard. I came accross this problem a little while back and it turned out to be the GPU or Graphics ChipCheck my websit at www.powerjackrepair.com for a diagnosis help.
But basically elliminate the powerjack problem by removing battery, check what happens when you try to switch on. if no lights then carefully but firmly wiggle the power Plug that is inserted in the jack side to side and see if you can get the lights to stay on. You can tell pretty much straight away if it does. Hold it in that possition and see if you get anything on screen, if so lett it boot up a little then move the plug, if it switches off then we are clear it is the powerjack. What happens at the very first instance when you boot up your computer is Bios then GPU (Graphics chip).
I hope this has helped.
All the best
Colin
Reply to carl97
- 0 +
Lights keep blinking until I press and hold the power button, and then it turns off. I already had removed even the cmos battery and the processor, nothing else is attached to the motherboard and it does exactly the same. Someone said that it could be the DC ower board, but it is part of the motherboard, so i can not replace it, but i thought that there would be a component or something i could replace, i just do not know which one. Thanks for the help
Reply to serzav
- 0 +
Hi Serzav,
Yes it does sound like the Power Board circuitry, It is likely you wont be able to repair that unless you have the skills and tools to test the circuit.
Depending where you are location wise it might not be too expensive to take it to a repair shop, but i doubt that, if you are in the UK you may be able to pick up a replacement board (Motherboard) for about £80, probably a lot less if you go second hand and you can find one. I wouldnt spend more than that on your machine unless its dear to you.
You will still be able to get your data back using software like "Get Data Back NTFS or FAT".
Please let me know how you get on.
All the best
Colin
Reply to carl97
- 0 +
The guy at powerjackrepair.com has produced a tutorial DVD Video for anyone interested in repairing the powerjack socket.
Reply to carl97
Do you need a DELL INSPIRON 8100 SERIES Laptop Battery? http://www.laptop-battery-inc.co.u [...] series.htm can supply the dell INSPIRON 8100 battery you need.
Reply to powerbattery
- 0 +
The reason the jacks keep breaking is from tugging, pulling or jerking on the AC cable.
What you and just about every other Laptop owner needs is a CRD (Cable Restraint Device).
Something that takes the strain instead of the cable connector at the computer when you jerk or tug or pull on the cable accidentally.
How do I know this? I had to fix both of our Fujitsu laptops because of the problem. I tried to find someone that sold a CRD but no luck so I invented one.
SHAMELESS PLUG ALERT
It's made out of ABS plastic, not steel like ENGADGET mentioned today and it really does solve the problem.
It's called the JerkStopper and can be found at www.jerkstopper.com
http://i13.photobucket.com/albums/a296/Compared2What/JerkStopper/RJ-45ASSEMBLY3-1.jpg
Reply to c2w
If anyone in the US is looking for DC jack repair, I had a great experience with Comprehensive Computing in Richlands, VA ( http://comprehensivecomputing.net/ [...] repair.htm ) I sent an Acer Aspire 3680 with a broken power pin in the jack, and they turned the repair around in 1 day and gave me very friendly service as well, FYI.
Reply to fantasmatron
I used Comprehensive Computing and it cost about $125 with shipping. But after six months, I have a loose connection again. Their new warranty allows a free repair if it is their fault. Anyway, for about $4 (US) you can get a plastic C-Clamp that will allow you to clamp the power cord to the monitor or base once your battery indicator shows that you are connected (charging). Of course the downside is that you must ALWAYS have your system plugged in. I purchased mine at Orchard Supply Hardware.
Reply to phlogiston2_41
- 0 +
Hi Colin
My Packard Bell Laptop stopped charging the other day and I found out that it was because the socket that is at the back of my laptop, (where I plug the charger into) had a loose piece which I took out by opening the back of the laptop. The piece happened to be some small pin. I took this to a repair and they said I need to buy a new one but I am not sure where I can buy this part and what it is called?1 I would appreciate it if u cud help me identify what this piece is!
Cheers,
Fraz
Reply to don87
- 0 +
I used orangecountycomputerexperts.com and it cost about $100 with shipping. The thing that is different with these guys is that they will solder and epoxy the dc jack so that you wont have the same problem a few months down the line.
Reply to octeks
There are 1345 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
