Ok, here goes...
I have 3 hard drives and 2 optical drives...
I need to put them all into a new system.
If I go with the Gigabyte GA-8KNXP Mobo I will have no problems, it has support for 8 IDE Channels
If I go with the Abit IC7-Max3 Mobo I will have to pop in my old PROMISE ULTRA66 Controller.
If I do that I will be putting only the optical drives on the PROMISE Controller, the Hard Drives will all go on the ONBOARD IDE Controllers.
My question is this. If i use the PROMISE ULTRA66 with the IC7-Max3 how will it effect performance of the optical drives?
(The optical drives are a Plextor PX-708A 8X DVD+/-RW and a Pioneer DVD-120S.)
I do alot of CD and DVD Ripping and Burning.
