SSD - The Performance Upgrade of the Future
Okaye. There is a problem with my NEC Laptop for a while now. The Keypad, There's something wrong, i'm unable to type anything on my keypad anymore. And that only the track pad works. Nothing comes out when i press on my key pad. When i open a Notepad, nothing surfaces when i hit the keys. But pressing F, pushes me to a 'FIND' option It's like there's a constant, 'Ctrl' button being pressed. As when i hit N, O, S, it goes to New Document, Open, and Save, respectively. Is there just anything wrong with my keypad? Or is it an internal language problem?.
Your keypad might be faulty. You could take it out and check for loose wiring and/or stucks keys.
You are about to answer a thread that has been inactive for more than 6 months.If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread.
