I did everything creative told me to do except changing the IRQ routing. But then a guy from mcplus support told me that changing the IRQ routing is dangerous. So I don't know if I should change it or not.
Did anyone have problems with there pc after changing the IRQ routing?
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
I'm pretty sure my cables a properly connected. 2 lights r "on" on the hub. The MIC output works. I'll change the batterie, and see. If it's not that it's the IRQ routing maybe.
I changed to a brand new batterie and still the light doesn't turn on on the hub when I press the buttons on my remote. It did light only a few times thought. But the light doesn't turn on all the time. It turns on ones every 30 button I press approximitly.
Why won't anyone tell me if the IRQ routing updates are in bios update???
Below is part of the response from creative support:
"Dear Customer,
Let us reinstall the drivers to make sure that we have the correct drivers installed in the system. Also, make sure that you have the latest BIOS and update for your motherboard chipset, including the IRQ routing."
So if windows sets the IRQ routing why are they telling me to update it? There's know way to update the IRQ?
You don't recommend to change the IRQ, why not? Creative will want me to try everything before I replace my remote. Is it cuz I might damage my comp? I can alwas use GoBack to revert the harddrive.
Why would I need to look for bus speeds? Don't make me waste my time.
Creative told me to install and update the latest IRQ files. Changing the card to another pci slot doesn't install and update the latest IRQ files. How can I get them?
I sugested you check and see if your PCI bus speed was at spec, you asked how, I told you to to look in Sisoft Sandra for bus speeds.
I'm giving up my time trying to help you, not wasting your time.
Creative isn't making any sense. There is no such thing as an "IRQ file". Just tell them you tried "updating the IRQ files" and it didn't work, and you want a new card & remote.
*Dual PIII-800 @900 i440BX and Tualeron 1.2 @1.7 i815*
