Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Problems with my Toshiba Satellite A105
Forum Laptops & Notebooks : General Laptops & Notebooks - Problems with my Toshiba Satellite A105
I got this laptop maybe like a year or two ago, and it's starting to give me some serious problems. I think I left azureus on on it for too long once and maybe damaged the harddrive. Now, it makes a lot of noise when it spins and I can't really copy or move large amounts of data at once. I have to space it out to make sure the hard disk doesn't give me a disk cyclical error or redundancy error or something like that. Also, later, the sound has started stuttering, and I'm not sure what went wrong. So, judging from the symptoms, would it be wise to replace my laptop's harddrive? Is it hard to find the drivers for the components again? Also, is replacing the hard drive easy? I don't want to waste 90 bucks on a slow 2.5 hard drive and then just end up **** up the process
thanks guys
Sponsored Links
Run the diagnostic/repair software from the hdd mfg but it does sound like the hdd. Good idea to get a new one unless you can confirm it's good. The manual should tell you how to replace the hdd. If it's a standard 2.5 drive, then any 2.5 should fit
Reply to g-paw
- 0 +
if you are still in warranty, might as well bring it to a toshiba authorize service provider for it to be checked and if you are in warranty the hard drive can be replaced. did you try calling the toshiba tech support? try calling this number 1-800-457-7777. they can help you on this.
Reply to badbigs
- 0 +
I am having issues with my computer that is the same model as yours. Only mine has half of my screen blacked out and the rest is fine. All my pages and everything fit to the part of the screen that does show up its like my screen is off center.
Reply to jdc256
There are 1224 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
