My phone Wont turn should i buy a New battery ?
Hello , i have got an Lg viewty ive had For a Few Mouths And now Sunndely It wont Turn on at all , I think it may be the battery , but i dont want to have to buy another Phone what should i do ?
Many thanks
1 answer Last reply
More about phone wont turn battery
  1. Batteries normally fail slowly so that you notice they're not holding a charge for so long or are going flat quickly in use.
    Could be the battery, the phone or the charger.
    Take all three to a retailer/repair guy and see if he will check it with a battery that's known to be working. Or see if a friend with an LG has the same battery or charger.
Battery Phones LG Mobile Computing
