Tom's Hardware > Forum > Computer Peripherals > Other Peripherals > a4tech office kbs-26 keyboard problem with the multim. keys
Forum Computer Peripherals : Other Peripherals - a4tech office kbs-26 keyboard problem with the multim. keys
hi
i've just bought an a4tech office kbs-26 keyboard, and i have some problems with the multimedia keys (play, stop, ...) controlling the winamp, or anything else (like windows media player).
i have installed the driver...
do you have any ideas?
thanks.
Sponsored Links
If you have the drivers installed, then there must be a utility to customize what each key does. I doubt WinAmp or WMP would be default selections, so you should be able to browse each button to choose the program required.
Reply to RobD
- 0 +
hi
yes there is the default function (for example the "play" ), or i can assign a program to the play button. but there is no choice for witch program to unction the play button. while my friend has another a4tech keyboard, and if he presses the play button the winamp starts, and the music too. without any setting, just instlling the driver...
if i press the button on the bottom of the screen appears the icon of the button i pressed, so it functions, but i don't know why doesn't control the winamp... :cry:
Reply to rouwlee
- 0 +
ok, i've found the problem: it was the keyboard's driver. i've uninstalled and now works. but now doesn't work the scroll, and other keys, but it's not a such big problem :lol:
Reply to rouwlee
There are 577 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
