Yes No
Ads
Tom's Hardware > Forum > Computer Brands > Dell > Upgrade or Build a new system
Forum Computer Brands : Dell Upgrade or Build a new system
I bought a Dell 8400 in the Summer of 2004 and its just not cutting it anymore. I want a lil more eye candy and I am not sure what to do. I have a P4 3ghz, 1 gig of Samsung ram, a Creative Sound Audigy 2 and a Radeon 9800 pro 128mb. Should i upgrade the video card (only have AGP slot) or should i upgrade the motherboard and take out the cpu and all the other components except the RAM and transfer them over?
Reply to giangsta
It depends on how much money that you have. If you have the money and time to replace all those components of your computer, I would definitely say go for replacing the mobo.
Reply to crizazykid2
Is it relatively easy to remove the CPU from its socket or should I have some1 else help me?
Reply to giangsta
I would say that your CPU is fine. Dell will skimp on the hard drive though, so you might want to get a fast SATA drive and controller if you don't have any SATA ports on your mobo. Also your graphics could be updated with something like a nvidia 6800GT for AGP. You've already got 1GB RAM which is good.
I wouldn't try to replace the mobo in that system. If you are going to do that, build from scratch with a new case and everything. A standard board might not even fit in that Dell case.
Reply to ocularis
That is a good point...it did not occur to me though since I don't have a Dell.
- 0 +
for the love of god, build your PC
I have a Dell e510, and it is probably the worst PC i have ever owned when it comes to stability, compatibility, and upgradability (new word?)
I could have built a PC for $100 less, and it would have been more powerful, reliable, and upgradable.
Reply to mac1981
- 0 +
i second that vote. anything you build is better than whatever Dell can offer you -- price wise, performance wise, stability, take your criteria Dell will lose.
the trouble is some people are really afraid of doing this. it has to do with the warranty for some people, i think. individual components have warranties on them, so you should feel confident with that. if you buy from a reputable vendor you can return faulty parts, if you get any (i thought i have faulty RAM one time, but I just had to use different DIMM slots -- then it was fine).
at work we have a contract with Dell (I absolutely hate this fact) and I was asked to price out 3 new comps, for myself, my boss and someone else. it ended up being like $1300 each and it was very basic really -- 820 CPU, 1GB DDR2-533, 160GB, 17" lcd, radeon x300 (default). it's just insane, i could build an AMD system for around $900 that would be as good or better.
Reply to joex444
- 0 +
BUILD YOUR OWN COMPUTER
DELL SUCKS
Reply to tkbart5
- 0 +
Its annoying to take the proc out of dell pcs. I did it myself. As for HDDs, they usually are good, mine from my dell computer is a fast sata disk and its working very well.
Reply to kmac20
There are 2058 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What type of sound card does a dell dimentsion 8300 have
By Ubrales, 7 days ago:
Are the speakers turned OFF or disconnected? Check and make sure that the power adapter...
Best offers
