Tom's Hardware > Forum > Computer Peripherals > CRT Monitors > Viewsonic monitor question (please come in and see)
Forum Computer Peripherals : CRT Monitors - Viewsonic monitor question (please come in and see)
I purchased a refurbished monitor on eBay (Viewsonic p220fb). My question is as follows. If I move it around (like bump it or shake it slightly) it sounds like there is some rattling. It sounds as though there is a cage inside that is rattling back and forth. Is this normal for over-sized tube displays such as the one I bought, or so I need to send it back?
Now, I got a warranty, and seller had 100% feedback so an RMA shouldn’t be too hard to accomplish. Just want to know if I am worried over something that is typically normal.
Sponsored Links
I believe that is the display mask, thin wires to keep the geometry of the screen correct.
If screen looks good, you mon is good.
Reply to RichPLS
There are 588 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
