Archived from groups: microsoft.public.games (
More info?)
Hi asqe28,
"asqe28@*com" <asqe28@dsl.pipex.com@discussions.microsoft.com> wrote in message
news:4CD7C36C-01D5-40B8-A2F6-395D7C8FDD15@microsoft.com...
| I have got a game installed on my computer I try to uninstall it and it says
| it it has sucessfully unistalled but when i go to reinstall the game it says
| it is still on my computer but i can tfind the files for it anywere
| My computer is Windows 98
| Hop someone can help
Here's how to uninstall a game, especially tricky ones:
Step A: In Control Panel / Add-Remove Programs, remove the game and then delete the game's folder especially if you previously
experienced problems with a patch, or if you installed the Trial, Mods, NO CD patches, etc.
Note: Click Start to Search or Find your game. Many times there are two installs
of the same game on a system and the patch installs to the wrong one. Also if you
installed a Trial version of the game, this could be causing a conflict.. Uninstall it
and delete the folder.
Step B: Reinstall the game to the same folder and try uninstalling it
Step C: Install and Run Regcleaner and if it finds any stray registry keys for the
game, delete them. Reboot your computer, and then re-install the game.
Regcleaner Download:
http://www.majorgeeks.com/download460.html
Cheers,
Jimmy S.
Microsoft MVP Windows XP Shell/User:
http://mvp.support.microsoft.com
Additional Support Resources: My Zone.com Helpsite:
http://nibblesnbits.tk
Game FAQ's:
;gms]http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
My advice is donated "AS IS" without warranty; nor do I confer any rights.
_________________________________________________________
