Tom's Hardware > Forum > Home Theatre > HDTV > Help! HDTV to Home Theater to Cox Cable connections
Forum Home Theatre : HDTV - Help! HDTV to Home Theater to Cox Cable connections
Can someone help please?
I have Insignia 30" HDTV (tube) (Model NS-30HTV) and also Insignia home theater (IS-HTIB102) and a cox cable box. I have component video cables from the Cox box to the back of the TV. There is only one output for component on the TV. what do I do with the home theater video??? Everything seems to work ok except I can't see DVD's, can only get the sound. Can I run it thru some kind of AB switch??? Or what? Also, if I unplug the component from the Cox box and plug the home theater directly into the TV, my picture seems to be missing a color or two and there are lines thru the picture.
Please speak softly... I am a novice (could ya tell????)
Thanks!
Sponsored Links
Would I be correct in assuming by the age of your post you sorted it out already?
Reply to BBFBKev
There are 1282 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
