Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > ghosting problems with movies
Forum Computer Peripherals : Flat Panels/ LCDs - ghosting problems with movies
hi, this has probably been discussed a million times but im lazy.
i had been having problems with outlines of images staying on my monitor whilst watching movies. i don't watch alot of them but since games were fine i was pretty annoyed. on a black screen writing would fade but never completely go away and would overlap other images.
i have managed to solve this problwm by disabling de-interlacing. has anyone else suffered this problem and solved it by the same saction? also can someone explain if de-interlacing is for CRT's only and why.
again i'm sorry for posting a subject that has probably been discussed but it sometimes help to have a refresher. i tried searching for de-interlacing but got no results, and any searches for ghosting were usually queries about it by potential buyers.
Sponsored Links
De-interlacing is buffering and reassembling the odd and even frame data before writing it out to the display. You shouldn't see image sticking unless the de-interlacing is done badly.
Talk to Dell if you haven't already but I doubt they'll be much help. You've implied the monitor works fine off the computer.
Reply to Anchoku
no the monitor works fine with the comp but just with de-interlacing off. i just thought it might happen on other LCD's and was wondering why.
Reply to strangestranger
- 0 +
You won't want de-interlacing on anything from your computer. Even DVDs played on your computer get de-interlaced by software before your monitor ever sees it. De-interlacing should only be turned on for VCRs and old DVD players hooked directly to the monitor. Never use it for anything from your computer.
Reply to Anchoku
There are 967 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
