Windows 7 Starter 32 bit
hp-mini 110-3015dx
I cannot use wireless access, getting msg. wireless lan adapter has been disabled in device manager, checked device manager there is a Network adapter, (Realtek PCIE FE Family Controller) and then there is Other Devices under there is the network controller(yellow !). Downloaded controller drivers from HP,( sp53955) and for some reasons the drivers are not installing. Also when I try to set up a wireless connection all i can get is broadband and cable. I am quite sure this is because there is a problem with the wireless adapter.
I continued my search and discovered that this notebook uses the Atheros ar9285 wireless adapter, I disabled the unknown network controller and enabled the Realtek since this one appeared to be the one that was installed by HP. Downloaded and installed the Atheros drivers and still no connectivity. Please help. Oh I guess I should say that I purchased this laptop used.
hp-mini 110-3015dx
