I recently purchased this awesome headset and I seem to be having trouble finding out how to get it to work on my PC. I've read reviews where it seems like others are getting them to work but they don't bother telling you how they did it, or they do but Broadcomm made them take down the solution, rrrr.
So my question is this. If you're out there using the 590A on your PC for something like teamspeak for gaming, then please by all means tell me how you got this bad boy to cooperate.
I can get it to connect no problem. It even picks up as an advanced audio device. That's as far as it goes. No audio comes from the headphones, mic picks up nothing.
I am running WinXP Pro SP2 on an AMD Opteron 1.8G proc. with 4G Ram and the BT receiver is a high speed 2.0 dongle produced by Logitech. I am using Logitech's Widcomm driver for it, and maybe I just don't know how to set up my BT so this thing works. The headset comes with no software and Plantronics has NO tech support for this thing in regard to PC usage.
Please help! I'm about to RMA the thing and go with old trusty USB wired, I know it works. I was hoping to not have to do that. Thanks!
Did you run it through the windows sound wizard? What were the results? I have a Plantronics, not your model, that works perfectly with TS and games. It does have a swich on it that you can shut off, is that the case with yours?
Yes, mine does have a switch on it, but that's not the problem... So this windows sound wizard, how do I find it? I have definately not done that, and that's likely the problem!
Hey - did you ever get this to work? I was looking at buying this headset to use on my Windows Media Center PC as a microphone for World of Warcraft / Ventrilo, but wanted to find someone that was successfully using it 1st.
I have unfortunately not been able to remedy this problem :? . I did find the sound setup wizards and ran them. I also installed the widcomm bluetooth stack and disabled the microsoft stack successfully. I was able to successfully get sound out of the headphones, but no mic pickups :x . According to Plantronics support, this is the most I can expect out of them as far as PC usage goes I sure expected more for what you have to pay for them...
They do work fantastic as a phone headset, and can even be used in the car since the left earpiece will tuck up against the headband so it's not illegal. The bt audio transmitter adapter that comes with them works great with my nomad too. Just no mic on the pc, rrrrrr--->
I own this headset and after numerous hours on the phone with Plantronics reps attempting to solve this issue I finally got ahold of a rep that seemed to know what I was talking about.
He informed me that the hardware in the headset differs greatly from that of the older BT model headset they sell. It was not designed to function in the way I would like to use the set... as in being able to use the set as both a pair of headphones and a headset. While, yes, you can use them as a headset the quality is highly degraded because of the limitations of BT 1.0 and 1.1 due to the limited bandwidth available.
I have yet to be able to have the headphones work as an independant audio source with my systems, like that of a USB headset, as it appears the audio must still be processed by the soundcard chipset before being sent through bluetooth to the headset. It appears in audio set-up as a seperate audio source, but configuring the system to use it directly as an audio input but audio output through my system speakers resulted in nothing. The reps at Plantronics have no explination, not even the engineer.
Driver updates, firmware updates, OS reinstall... nothing works.
If you bought this headset to work as a wireless set for Ventrillo or something similar... take it back and get a USB headset instead.
