diesel96 :
Hello, i am having problems with my laptop that i just put a fresh windows 7 home premium install on. The wifi card is a 802.11bgn + bluetooth combo. It is not showing up in device manager and i dont know the brand to look for drivers. What can i do?
Laptop : IBUYPOWER CZ-12
http://www.ibuypower.com/Store/espec.aspx?eid=156112
IF you scroll down you can see the card.
Thanks in advanced.
Best thing to do is, to go to device manager and see if there are any devices listed that has a yellow (or red) icon next to it indicating that the device doesn't have proper drivers loaded or isn't working properly.
your Wifi device will be listed (if the hardware is recognized) as either unknown or network device with a yellow (or red, worse) icon next to it. Right click on it, and it may recognize the brand, if not, you will have to check out its hardware IDs from the drop down list box and paste that into google to find out what card that is, and who made it to get the drivers.
OR, usually the wireless cards are easily accessible from the back of the laptop via a small plastic panel. Check to see if any panels on the back of the computer hides the wifi card. it will have a few antennas attached to it, and about the size of 1x1 inches or 1x2 inches.
OR, check in the manual. It should have a list of devices in the computer, to find out who made the wifi card.
OR, at the back of the laptop, there is a sticker about the wifi card. If you still have this sticker, it *might* tell you who made the card, and the model. Usually this sticker is the sticker that contains the FCC ID for wifi communications.
-Try those.
