Samsung signal issues
  • Wireless Access
  • Phones
  • Samsung
Last response: in General Connectivity
June 28, 2010 7:30:57 PM
Hi, Board - I wonder if anyone can help me with this one. I have a Samsung Omnia i900 and live in a poor signal area. However, I seem, to have discovered a correlation between having a good signal then losing it by handling the phone. When I pick it up to answer it, I immediately cut off the call.
Does anyone know if it's possible to get round this by fitting an external aerial?
More about : samsung signal issues
Anonymous
a b Ô Samsung
June 29, 2010 4:28:27 AM
This sounds like the issue which has marred the new iPhone launch. They've run the antenna around the casing so that the phone works fine if you balance it on a table and shout at it but has a problem with signal when you actually hold it -- like a phone ! I'd go back to the supplier and see if you can duplicate the problem and demand a different model.
June 29, 2010 9:47:39 AM
Thanks for that, fihart - it was all the fuss about the iPhone problem that made me think it may be my issue as well. It's fine in my car even when only parked outside, because the hands free takes over and the 'phone can sit in the cupholder which, being plastic, doesn't affect it. I've tried a bluetooth dongle but I still have to touch the darned thing to make or answer a call. doubt the maker would do anything now - I put up with this since March of last year blaming O2 for lousy signal at home. Anywhere with a sufficiently strong signal still lets wnough through to allow for me touching the unit.
I've ordered a set of earphones on e-Bay because my own have gone adrift - maybe they'll help the situation. No point in looking inside to poodlefake an external aerial then?
Anonymous
a b Ô Samsung
June 29, 2010 1:35:26 PM
Poodlefake (whatever that is) would doubtless invalidate warranty !
August 21, 2012 6:18:24 PM
Server
