Power options turn off display and computer sleep acting wierd.
Last response: in Windows 7
- New Build: Power button won't turn off computer, No Display Forum
- 15" MacBookPro will not start. Black screen. Sleep light is on, but will not turn off. Tried all options I know, no results Forum
- SolvedComputer hangs and display turns off but power is still on Forum
- SolvedComputer wakes up out of sleep when i turn off ceiling fan. Forum
- So my computer is really acting bad, after I turn it on it will turn off about 10 seconds later and nothing will be on the scr Forum
- Overclocking FX 6100 Bulldozer, is it necessary to turn off power savings options? Forum
- Can I bring up the "Turn Off Computer" options like on windows XP, on windows 7 Forum
- SolvedEverything open on my computer, stops responding, task manager wont open, and my pc wont turn off unless I hold down the power Forum
- Solvedcomputer infrequently turns off while in sleep mode Forum
- Solvedis it OK to connect 2 monitors and turn off 1??will the turned off display take power??? Forum
- SolvedComputer won't boot after switching off power supply while in sleep mode. Forum
- SolvedMy computer turns off completely when I put it into S3 sleep (like someone just pulled the plug). Forum
- SolvedPower Options: Turn Hard Disks off after xx min? Forum
- ASUS PB278Q has trouble picking up signal after sleep mode and when the computer is turning on from being off. Forum
- SolvedComputer Won't Turn OFF After Power Surge Forum
- Comp entering power save mode when its set to never turn off display Forum
- SolvedMy SLI GF 560's work harder (+20 degrees each) when I turn my TV display off, and computer is idle. Forum
- SolvedMy computer's clock resets whenever I turn the power off at the wall Forum
- My computer wont go into sleep but the screen turns off when i try to put it into sleep. Forum
- Is there a PC sleep timer to turn your computer off at a later time? Forum
- More resources
Read discussions in other Windows 7 categories
